mixchief
Flight distance : 182057 ft
solentlife Posted at 2018-2-14 10:01
Yep ... have that as well.
I tried a box like affair later ... that was better ... basically I added a roof at an angle to the 3 sided shade. It helped but still only halfway to a readable screen.
The Hoodman or PGY TECH hoods are great, Hoodman twice as much money. I use the PGY, cuz I'm cheap, I think the hoodman is better quality. The great thing about these two is that you can put your face right up to them making them virtual goggles, believe it or not my brain goes into total immersive mode. They both have a slit with elastic bands to prevent light from entering and creating reflections, but this slit can be a bit of a chore if you are accustomed to making most of your adjustments on screen. Additional downside is that they get a bit heavy after a while and throw the balance of the RC way off making it a bit of a chore to carry around, the angle you set for the screen always gets thrown off also. That said, in liew of a CS or goggles I find these to be the best solution, even with the downside. |
