Height Failure at 0 feet Problem With Spark Please Help
2749 16 2018-2-14
Pmonahan
Hello,
I have my spark for 6 months now and have a problem where it says it is at 0 feet when it is actualy for example is at 60 feet, then when I try to descend it goes into a landing mode 60 or 70 foot in the sky and takes a very long time to descend, What component failure could be causing this? and is it under any gaurantee or warramty? I have updated to the newest firmware so that should not be the problem. Anyone else experience the same ???? Thanks . https://www.youtube.com/watch?time_continue=8&v=aBHVXM3pEfg     Here is a YouTube video showing the problem
2018-2-14
dj_dread
Flight distance : 648399 ft
Romania
would you please upload your flight logs here: http://www.phantomhelp.com/LogViewer/Upload/
what phone are you using? what is the firmware version for Spark? and what version of DJI G04 app you are using?
2018-2-14
Pmonahan
dj_dread Posted at 2018-2-14 12:31
I am using the latest software on the drone, DJI Go 4.0 on my Galaxy S7 Edge
2018-2-14
Pmonahan
2018-2-14
dj_dread
Romania
still, would be good to see the logs. maybe some error messages can be seen there.
also, were you using an OTG cable?
2018-2-14
Pmonahan
No OTG Cable, funnily enough  a week ago it said downward sensor failure please land immidiately, hasnt said it since the update but very confusing
2018-2-14
dj_dread
are the sensors clean?
the logs may help though to understand the issue
2018-2-15
DJT_MVSP
Flight distance : 2018645 ft
Singapore
Seems like you might have crashed or dropped it?
It seems that there might be light bleed of the infrared TOF sensor on the bottom
2018-2-15
Spark in the Park
Flight distance : 725961 ft
My spark is doing the exact same thing since latest update except it tells me im.at a negative atlltitide when im over 100 meters up in the air..as result it refuses to land... its only started happening since latest android app release.
2018-2-25
hg87
Flight distance : 117123 ft
Interesting, my flight record states mine was 600 m in the air which is definitely wrong. Sort of the opposite of your problem. Looks like there may be something wrong with the altitude readings.
2018-2-25
J4k4ls
Similar problem here after update, takes off, then starts 'bouncing', going up and down, touches the ground, shoots up to a meter and then bounces in between. Anyone seen a fix for this yet?
2018-7-21
S-e-ven
Flight distance : 5922034 ft
Thailand
J4k4ls Posted at 2018-7-21 22:36
If it looks like this:
that is a different problem, methinks
Watch the video and stop, as workaround, to start with the app-slide-start.
Use the stick, slowly
2018-7-21
J4k4ls
Hi S-e-ven, that is exactly what mine does, many thanks for the video, I will try the work around a bit later and confirm if it does the trick. This is serious though, not a fix, hope DJI can do something about this. Sent them an email, see what they say as well...thanks again.
2018-7-21
J4k4ls
Update, although the symptoms in this video is exactly what I am experiencing, the work-around unfortunately does not work, Spark still bouncing like a mad-man. Waiting for DJI support to get back to me...
2018-7-22
J4k4ls
*Update*
Oh dear, DJI asked me to send the Spark in for repairs to their Netherlands centre as they had to replace the height sensor. To be fair, they have been really quick (although I had to pay UPS to collect the drone) - Now however, the drone is in a worse state that it was before, the cooling fan is making a hell of racket when you tilt the aircraft and cant be flown as I have the following errors on-screen:
Camera Sensor Error – Hardware Malfunction. Contact DJI Support to for repairs
Forward Vision Sensor Error (80004)
Air Encoder Error (0x800000)
....me thinks its time they just replace it under warranty....fingers crossed!
2018-8-4
djiuser_CzhIMkJ8zFl4
Hi, same thing with my spark. Height go to -2m when i start the motor. After 3meters no problem but bounce when i want to Land off. Before upgrate to Last version (1.0.100) there are no problem... I tried to downgrade but no effect...
2019-10-14
Hi, why my spark bounding to the wall after an upgrate to vers 1.00.1 and in red health decreased at start ?
https://youtu.be/WEkZGUY_--8
Thanks a lot for any help
2019-10-15
