Chasing Light & Shadows
Flight distance : 221476 ft
If you stream it to a standard HD TV it will be barely noticeable or on a mobile pone but on a high quality monitor you'll notice it more.
In this instance what you're seeing is GOP interframe flicker and just general noise from the small sensor/low light, best way to fix it is with Neatvideo.
Personally I wouldn't bother removing it unless it was for pro reasons.
In premiere pro bring up the colour scopes and advance by 1 frame at a time, you'll see a spike every 8 frames, when you find a spike advance frame by frame and count, you'll see what I mean. Also you can zoom in on the video and as you're going through frame by frame you'll see it correspond with the spike on the scopes. |
