Solved Problems; Crystal Sky, Mavic Air, PolarPro, Fat Sharks
3971 31 2018-2-14
LaurenOE
Flight distance : 969452 ft
Ok, so this has been kicking my butt since I got my Mavic Air.
I already own the smallest Crystal Sky Monitor that I use with my P3P.I can't live without FPV flight.
The latest firmware fixes the link to the Mavic Air and Crystal Sky.
With the Mavic Air, I can use the HDMI out of the Crystal Sky as my FPV to my Fat Sharks - it would be great if DJI sent the FPV data like the Phantom does, to the HDMI as an option, but that is for another thread. So FPV to the Fat Shark is solved.
So how do I use the Crystal Sky with the Mavic Air and retain quick disconnect with my Phantom too?
Buy the stock DJI Mavic to Crystal Sky mount? Nope. There is a better way!
Buy the stock DJI Crystal Sky mount - the one that goes to the Phantom/Inspire Controller - and then buy the Polar Pro Mavic to Crystal Sky Mount. Not the way DJI wanted, but it is fantastic as the Polar Pro was engineered to do exactly what I did.
I called Polar Pro to verify too.
Everything is now solved!
The only issues?
PolarPro will not sell the lower part separately, so you have to buy the whole thing - I asked.
The DJI stock mount is not cheap either, and there is a slight curve to the bottom of the mount to match the Phantom/Inspire controllers that would be better flat to match the PolarPro lower.
2018-2-14
windstar3
Thanks for this. It is at least a solution.
Just for not making a mistake, I need this:
Polar Pro Crystalsky Mavic mount
and this
DJI Crystalsky mount Phantom
and combine it to the above?
2018-2-16
Wyke
Flight distance : 33166 ft
I like that idea, as I prefer the DJI quick release, but more costly. I’ve just purchased the 5.5, and am waiting on its delivery. Given I also need to buy a charger too, I think I’ll be using Velcro for a bit, until my funds are looking healthier.
2018-2-16
lannes
Flight distance : 4465 ft
I still like my DJI Mavic CS mount with the MA controller
2018-2-16
LaurenOE
windstar3 Posted at 2018-2-16 01:23
Yep.
When you screw the DJI mount to the Polar Pro, just make sure you don't tighten too much, since there is a curvature to the DJI mount that does not match the Polar Pro. I used the stock DJI screw that comes with the DJI mount.
2018-2-16
LaurenOE
lannes Posted at 2018-2-16 03:25
[view_image]
I'd love to know how you got around the holes not aligning to the handles of the Air controller?
2018-2-16
LaurenOE
More Pictures!
2018-2-16
Wyke
LaurenOE Posted at 2018-2-16 09:06
He used Spark handles and swapped out the Air’s
2018-2-16
LaurenOE
Wyke Posted at 2018-2-16 09:19
Ahh...so I would need a Spark/Controller!!!
Then I wouldn't have spark handles?
I think that route would be even more expensive!
Unless you can buy Spark Handles as parts?
2018-2-16
Wyke
LaurenOE Posted at 2018-2-16 09:30
I don’t believe you can buy the handles, I think he tried, or someone did.
2018-2-16
LaurenOE
Wyke Posted at 2018-2-16 09:32
So at the end of the day, my (and others too) method is probably cheaper, preserves the CS disconnect, allows adjustable angles, doesn't crimp the DJI cord into the USB on the controller and even looks stock too. Not a bad solution IMHO. ;)
2018-2-16
Wyke
LaurenOE Posted at 2018-2-16 09:34
Yep. But still too rich for me at the mo. Two strips of Velcro is more my budget
2018-2-16
LaurenOE
Wyke Posted at 2018-2-16 09:39
Time to pass the collection plate around! Bake sale?
2018-2-16
lannes
Flyinghighusa also produce the plate by itself, however you still need the DJI bracket, but it is a bit cheaper
https://flyhighusa.com/product/m ... r-mounting-bracket/
I now use this with the Spark controller and the CS, after the jaws transplant to the MA controller
A little bit different to the Polar pro, but it has been designed to fit the DJI CS Phantom style mount perfectly and it's flat to match the base of the bracket
2018-2-16
lannes
Yours is a great solution for a new CS owner, many of us have the existing DJI Mavic CS mount already so I was trying to figure out a solution for the MA using the existing Mavic mount.
I don't tend to use the CS with the Spark a lot, so when you swap the handles between the controllers you can still use both, just the Spark with a normal tablet or phone held in the transplated MA jaws
Mine is only a temp solution until DJI decide to produce a compatible bracket, some others have elongated the holes in the jaws and and filed down sections of the inner plate, but I didn't want to be so destructive just in case I wanted to sell the MA.
2018-2-16
Wyke
I’ve just bought the PolarPro unit. The quick release would be nice but not justified at the moment.
2018-2-16
LaurenOE
lannes Posted at 2018-2-16 13:15
Cool. That works. I've had my CS for a long time, been using it on my P3P, so that is where I come from.
2018-2-16
LaurenOE
Wyke Posted at 2018-2-16 13:45
Yep. If I only had one drone, and one controller, I think the Polar Pro is the nicest out there.
2018-2-16
Tommyxx
Flight distance : 33898 ft
RE: Solved Problems; Crystal Sky, Mavic Air, PolarPro, Fat Sharks
[view_image]
Ciao,
Mi puoi dire come hai fatto ad istallare Crystalsky con rc Mavic Air ?
2018-2-18
lannes
Tommyxx Posted at 2018-2-18 05:04
Ciao,
Ho pensato che non avrei più usato le mie unità CS con la mia Spark.
Così ho tolto le mascelle dal mio controller Spark, 4 piccole viti e le copertine si staccano.
Poi ho trasferito le mascelle al controller MA e le ho riavvitate.
Il supporto ora si adatta perfettamente senza dover tagliare o hackerare il controller MA.
Ogni volta che voglio tornare indietro è un lavoro di 5 minuti per trasferire le mascelle.
2018-2-18
Tommyxx
lannes Posted at 2018-2-18 05:58
Ok ok grazie
2018-2-18
Aeromirage
Flight distance : 1778045 ft
I went with the Fly high piece and the DJI quick release.
2018-2-18
Tommyxx
Un consiglio,
Crystalsky è un buon prodotto ?
Per ora utilizzo iPhone X in settimana mi arriva Crystalsky!
2018-2-18
lannes
Tommyxx Posted at 2018-2-18 10:52
Un consiglio,
Se fai molto volare, va bene.
Ma è un'unità molto voluminosa e una grande unità con una grande batteria sul retro, solo per uno schermo da 8 pollici. Un ipad mini 4 è molto più compatto ma non così luminoso.
Non è il design più moderno con un processore lento e solo Android 5.1.1
Molti CS Ultra hanno avuto problemi di retroilluminazione che non possono essere riparati.
Se stai acquistando un Ultra, prendilo da un rivenditore autorizzato DJI italiano, così puoi facilmente restituirlo se fallisce.
Direi a meno che non vogliate averne uno, aspettate che rilascino la prossima generazione di CS, un ipad mini 4 di seconda mano vi darà le stesse dimensioni dello schermo e la stessa potenza di elaborazione
2018-2-18
Tommyxx
lannes Posted at 2018-2-18 14:25
Grazie per tutto!
Spero solo di non pentirmi di averlo acquistato..
Preso usato da un venditore autorizzato a Euro 400,00 con fattura di acquisto data 1/08/2017
2018-2-19
lannes
Tommyxx Posted at 2018-2-19 02:02
Grazie per tutto!
Buona fortuna con il nuovo CS, divertiti
2018-2-19
Tommyxx
Consiglio alimentatore per la ricarica della batteria crystalsky ?
2018-2-19
Aerial-Pixel
Flight distance : 2450935 ft
I did the same thing with mine, thought I'd try it and it worked. Was getting ready to post the solution when I saw yours.
2018-3-13
lannes
You can get these from ebay
https://www.ebay.com/itm/DJI-Mav ... 804546e4:g
2018-3-13
Tommyxx
Aerial-Pixel Posted at 2018-3-13 17:48
I did the same thing with mine, thought I'd try it and it worked. Was getting ready to post the solution when I saw yours. [view_image]
Ciao,
basta cambiare solo le maniglie?
I supporti stick non danno fastidio?
2018-3-15
Todd in Chicago
Flight distance : 513757 ft
[view_image]
I know...this is just so clean.
I actually prefer this to having the CS mounted "above" the controller (not on the same plane).
Cheers...
Todd in Chicago
2018-4-25
kalex
Flight distance : 11148 ft
Anyone has a guide on how to swap the arms for this?
2018-4-30
