Aardvark
Flight distance : 384432 ft
Which display device are you using ?
To do a factory reset, and /or firmware refresh on aircraft, then that needs to be done with Assistant 2. There have been some problems with Assistant 2 installing correctly on PC. So try installing again (as Administrator), or perhaps an older or newer version (V1.1.6, V1.1.8, V1.2.0 & V1.2.2 are all fairly recent).
The first LED on the RC should be green when all powered up and it is communicating with the aircraft. After that the Display needs to communicate with the RC, and that can be a problem sometimes.
