RedHotPoker
Flight distance : 165105 ft
Nigel_ Posted at 2018-2-16 02:20
Assuming that there is air in the box, the props will push on the air with a force equal to that required to lift the drone, the air will then push on the box with a force equal to that required to lift the drone, so the downward force on the box does not change except for when the drone is accelerating or decelerating, but the drone can't accelerate for long without hitting the top of the box and the scales will not be fast enough to see that.
With a very large box mounted on some springs and a very large drone you could make the box jump up and down, but on average there would be no weight change.
An interesting investigation, non the less. I like seeing scientific discoveries by test and error.
RedHotPoker |
