DJI Diana
Flight distance : 2408 ft
Hi Stan Campbell, sorry to hear about the technical troubles you are experiencing but a recommended device is really advised to be use. Also, correct me if I am wrong, did you mention you tried using the Samsung S5? If yes, that should work as long as everything is updated to the latest version. If you do not have a remote controller for the Spark, you may try to re-connect your phone to the Spark's WiFi and use the password inside the battery compartment after resetting as shown in the photo below.
