stuka75
Flight distance : 85682 ft
Absolutely not. One app only in mmeory at one time. You need the Go app to perform IMU calibrations, but both apps should be forced closed before before using either one. Thats on Android. Not sure how IOS works, but neither app should be in memory, and just closing the app does not do the trick. Even between batteries, The Go app will need to be forced closed after the first battery on occasion, not always. . Also, be sure any other wifi enabled devices that have connected to the P3 have their wifi turned off. Like any wifi signal, multiple devices can connect to the P3, degrading the controller signal. |
