Kloo Gee
Flight distance : 16783757 ft
Make sure that when you do a compass calibration that you are doing it in a wide open area without any potential magnetic interference or metal objects anywhere near you. Press the calibrate button, then set you phone and RC down and take a step or two away from it. Make sure that there are absolutely no metal objects on your or in your pockets and that you are well away from everything. A good open park lawn or field is a great place to do it in order to ensure no interference.
Once you get a good calibration with no interference, then you shouldn't have to do it again. If you get a message saying there is magnetic interference and to calibrate, don't calibrate again! Get away from whatever objects you are near before you try to fly. Then when you are flying, make sure not to fly near any big metal objects.
If you do as suggested above and continue to get interference, then it may be time to open a ticket with DJI support (http://dji.com/support).
Good luck! |
