SD card
2891 28 2018-2-16
chopperphil
I can't find in the Mavic Air manual where it says what the max micro SD card it will take. anybody know?
2018-2-16
StanfordWebbie
Flight distance : 178018 ft
A google search turned up this.  Read the 3rd posting:
https://mavicpilots.com/threads/ ... 2-gb-sd-card.33134/
2018-2-16
LoSBoL
Flight distance : 666483 ft
Since the Mavic Air accepts XC specification cards I would guess the biggest available would work. Many advise not to go to big, because if you loose your drone, you loose your footage. I think 64 GB is the sweet spot.
Just make sure its a 'UHS-3' speed card, or else it could be deemed to slow for recording video.
2018-2-16
A CW
Flight distance : 13838848 ft
This is from the DJI specs sheet on the Air: -
SUPPORTED SD CARDS
Supported SD Cards
microSD Class 10 or UHS-1 rating required
Recommended microSD Cards
16G Sandisk Extreme
Kingston 16GB SDHC-I SDCAC/16GB
32G
Sandisk Extreme V30
Sandisk Extreme V30 A1
Sandisk Extreme V30 Pro A1
64G
Sandisk Extreme Pro V30 A1
128G
Sandisk Extreme Plus V30 A1
So 128gb is the max.
2018-2-16
LoSBoL
A CW Posted at 2018-2-16 10:32
SUPPORTED SD CARDS
128 isn't the max, 2 GB is going to be the max, the problem is the availability, Sandisk doesn't make U3 cards yet that that go beyond 128 GB.
2018-2-16
A CW
LoSBoL Posted at 2018-2-16 10:54
2gb Micro SD card is the max? I think you've made an error there LOL
2018-2-16
mainstain
Flight distance : 178566 ft
LoSBoL Posted at 2018-2-16 09:45
Just make sure its a 'UHS-III' speed card, or else it could be deemed to slow for recording video.
Talk about confusing memory card specs... "UHS-III" (roman numeral) is actually a brand new UHS bus speed with a second set of pins for ultra fast data transfer. The cards are still pretty rare and expensive.
The Mavic quads use cards with 1 set of pins (UHS-I). UHS-III will work (because they are backward compatible), but you will not see the speed increase.
What you're talking about, and the one you want to get, is "U3" as opposed to U1, which uses the UHS-I bus.
In addition to the U3 marking, you will also see the roman numeral I, indicating which UHS bus it uses.
This article explains in more detail:  https://fossbytes.com/uhs-ultra- ... s_i-uhs-ii-uhs-iii/
2018-2-16
dari_017
Flight distance : 6016004 ft
I use the SanDisk Extreme PLUS 128GB microSDXC UHS-I Card - SDSQXBG-128G-GN6MA https://www.amazon.com/gp/produc ... 0?ie=UTF8&psc=1  , I have 4 batteries and this is more than enough for me. Plus this thing is fast !
2018-2-16
LoSBoL
A CW Posted at 2018-2-16 10:59
You are right, I meant 2 TB
2018-2-16
Mavic Ace
Flight distance : 333976 ft
I've used both Sandisk Extreme and Samsung EVO 128GB and they both worked great.
2018-2-16
LoSBoL
mainstain Posted at 2018-2-16 11:00
[view_image]
And you are right also, thanks for the correction
Resume: get one with the 3 in a bowl
2018-2-16
A CW
LoSBoL Posted at 2018-2-16 11:11
2TB? Can you post the link where you found that info please?
2018-2-16
mainstain
Here's one! I'd love to hear how well it performs!
https://www.amazon.com/SanDisk-E ... ance/dp/B077W3DG9N/
2018-2-16
LoSBoL
A CW Posted at 2018-2-16 11:13
https://www.sdcard.org/developers/overview/capacity/index.html
The Mavic Air uses the SDXC standard, which has a maximum of 2 TB formated exFAT
2018-2-16
A CW
LoSBoL Posted at 2018-2-16 11:20
So why haven't DJI listed this:  -
2018-2-16
mainstain
A CW Posted at 2018-2-16 11:29
https://www.amazon.com/SanDisk-Extreme-microSDXC-Adapter-Performance/dp/B077W3DG9N/
I highly doubt they had this card to test with when they wrote the manual (probably still don't). It's so new, it doesn't have a single review on Amazon yet. They're not going to recommend or guarantee compatibility with a card they haven't tested.
I doubt that testing that card, that few of their customers will ever purchase, is high on their list of priorities. Spec-wise, it should work great.
2018-2-16
A CW
Also why is the Mavic Pro only listed as 64gb exFAT max and I know for a fact 128gb is not compatible?
2018-2-16
LoSBoL
Like mainstain said,
I've bought my fair share of digital camera's, and they all listed lesser capacities because the unavailability of higher capacity cards at those times, but they all could use bigger then the listed ones, they just had to stick to the standard, and its that standard which limits the capacity.
And you could say it actually is listed, under the first 2 sentences:
'Supported SD Cards
microSD Class 10 or UHS-1 rating required'
2018-2-16
LoSBoL
A CW Posted at 2018-2-16 12:02
Are you having problems with a 128 GB card on the Mavic Pro? I can't find many problems if I google.
2018-2-16
A CW
It’s not compatible - works fine on my P4P though. Why would that be?
2018-2-16
LoSBoL
A CW Posted at 2018-2-16 12:37
I really wouldn't know, probably a good thing the Mavic Pro is rated to be supported to 64GB max. What make and series is the card?
2018-2-16
A CW
Sandisk Extreme Pro. To fill my 128gb shooting 2.7K @ 30p on my MPP would take about 10+ flights anyway and I import my files after 3 as a general rule so 32 and 64gb are more than sufficient. I think a 2TB card would cost more than the drone LOL Anyway, thanks for sharing your knowledge - appreciated.
2018-2-16
LoSBoL
A CW Posted at 2018-2-16 12:46
Your welcome
I got a 64 GB card with the MA and I really don't need or want it to be bigger either, I do know that I need a bigger harddrive now though
2018-2-16
A CW
LoSBoL Posted at 2018-2-16 13:01
Your welcome
If the drone crashed in the sea and your previous 10 flights are still on the card that would bother me as much as losing the drone! I tend to use 32gb now on the smaller drones.
2018-2-16
DJI Thor
Flight distance : 13602 ft
Thanks to the participants, please refer to A CW’s reply on 4#, you can also check the info on the specs in the official website. https://www.dji.com/mavic-air/info#specs
2018-2-17
Hexacopter
Be aware of fake SD cards https://www.phonearena.com/news/ ... he-original_id77769  that are being sold online!
* hex *
2018-2-17
LoSBoL
Hexacopter Posted at 2018-2-17 06:14
Be aware of fake SD cards https://www.phonearena.com/news/Beware-of-fake-microSD-cards-Heres-how-to-tell-a-counterfeit-from-the-original_id77769  that are being sold online!
* hex *
Good tip, I wouldn't order any SD cards on Aliexpress or Ebay out of China
2018-2-17
Datadogie
Flight distance : 27028 ft
The bigger the card the more you lose if lost or broken. Some people suggest buying a few 16GB cards so if worst comes to worst you have only lost a maximum of 16GB.
2018-2-17
VLOGNOSIS
The nomenclature of these cards is hysterical. Soon enough we'll have requirements such as "class 10 U3 UHSIII-VI (') Tertiary Z Unimatrix 07 A1 # Type H"
2018-2-17
