OTG cable does work on Android!!
16561 25 2018-2-17
MJLSTUDIOS
Flight distance : 1540131 ft
I use a Samsung Tab S2 (8 in.) as my mobile device. If you connect by following these steps it should work for you too. All flight telemetery and battery levels ARE displayed on the mobile device.
1.Connect the USB Cable to the OTG cable.
2.Connect the USB cable to your android device.
3.Start your Spark and RC.  Wait till they connect (Solid green light on the RC)
4.Start the GO 4 APP on your android. Wait till it connects and tells you to "GO FLY"
5.Connect the OTG cable to the RC.
6.Click on the "GO FLY" button on the GO 4 App.
On MY Samsung Tab S2 I get all information needed to fly. ie. Height, VS, Distance, GPS Sat. Battery level, etc.
2018-2-17
hallmark007
Flight distance : 9827923 ft
Hopefully this helps others with similar problems connecting.
2018-2-17
mali
Flight distance : 55066 ft
Serbia
problem is ,with most android phones ,that they dont connect with wifi from RC,so step 4. doesnt work.and when connected with otg,there is no telemetry data.only working solution is dji go 4.1.15.
2018-2-17
Grmachine
Question, did you turn off WiFi on your device after you connected the OTG cable?
2018-2-17
CetanTopa
Flight distance : 158366 ft
Norway
that's my experience also....
2018-2-17
MJLSTUDIOS
Grmachine Posted at 2018-2-17 07:07
Nope. Kept the WIFI going.
2018-2-17
1wak
Flight distance : 52005 ft
Not workin on my Lg STYLUS 2 droid version 7.0  wifi works
2018-2-17
S-e-ven
Flight distance : 5922034 ft
Thailand
And you are sure, you are OTG and not wifi connected?
My guess is, the wifi is still on to the RC!
>>>Nope. Kept the WIFI going.<<<
2018-2-17
Flighty
Flight distance : 1977175 ft
Croatia
Without deselecting wi fi off, I am sure you are are still on wi fi and not actually on OTG??,, on my iPad I have to select wi fi off,, otherwise no OTG connection!!
2018-2-18
dj_dread
Flight distance : 648399 ft
Romania
On my iphone6 I do not need to switch Wi-Fi off. ORG will connect RC to phone will phone's Wi-Fi will stay connected to the internet. Just checked
2018-2-18
MJLSTUDIOS
Flighty Posted at 2018-2-18 00:43
Yup, you are right. Just retest the connection and when I shut WIFI off the flight data showed zero or N/A....crap!
2018-2-18
MikeTheBik68
Flight distance : 77979 ft
MJLSTUDIOS Posted at 2018-2-18 05:56
So......?
OTG is definitely NOT working under Android (DJI GO4 v4.2.6).
#NO batterystatus.
#NO flight data.
#NO nothin' @all.
On the other hand, the IOS version DJI Go4 V4.2.6 is working well with the OTG cable.
2018-2-18
Jezmo
dj_dread Posted at 2018-2-18 02:52
WiFi will be used if turned on instead of the OTG on my IPAD. I went and checked.
2018-2-18
djiuser_35ymB9CsQoBd
Flight distance : 296112 ft
Croatia
As I mentioned earlier. OTG is working on android 4.2.6. I have battery, and flight data but no satelites..
2018-2-18
Dudarude7
Flight distance : 20994 ft
Switzerland
djiuser_35ymB9CsQoBd Posted at 2018-2-18 09:52
wich android do you have
root rom?
sony ?samsung? htc? huawei?
they are all a little different.
2018-2-18
S-e-ven
But no screenshot or -video or info about your device
Can it be, that your wifi is on and connected to the RC?
2018-2-18
S-e-ven
Try that in the wilderness with the only "internet" is the RC's wifi.
2018-2-18
Croatia
Noa Hummer is mobile phone. Wifi is deactivated before going in Dji GO 4 app..
If weather would bi better this days, I will do screen video.
2018-2-18
dj_dread
Romania
S-e-ven Posted at 2018-2-18 14:52
That is different indeed. But inside the house i was testing the live streaming function. Cable connected to phone, all telemetry showing on the screen, and i was specifically checking the wifi several times and it was showing connected to my home wifi. Ofcourse out in the field the only wifi available would be the RC one..i'll test that as soon as the weather will allow..
2018-2-18
bjr981s
Flight distance : 139698 ft
dj_dread Posted at 2018-2-18 15:01
Do you have a an IOS device. Telemetry works fine on IOS.
2018-2-19
Croatia
2018-2-19
Vyborny83
Flight distance : 166014 ft
Czechia
FYI ... the OTG connection never stopped working physically. The problem is that since DJI GO 4 4.1.18 released last november, DJI has broken the readouts of essential flight data transmitted over the cable. If you look at the video you uploaded you will see you have no satellite data, no remainning battery, no height, distance and so on. It is practically unusable in this state as well as pretty dangerous. That's the reason why people say it does not work ;).
2018-2-19
Croatia
Ok thanks..
2018-2-19
mali
Serbia
and also there is no offline maps,so i run down to 4.1.15.and now otg and offline maps are working fine on mu sgs 6 edge ,also i run floater and turn fcc mode on,now im waiting good weather to test these settings!!!!maybe off topic?
2018-2-20
mali
Serbia
good video for EU users
2018-2-20
fans6df632d5
Flight distance : 15928 ft
Malaysia
up, waiting for OTG to come back for Android. Hopefully in 4.2.7
2018-3-19
