Geebax
Mark The Droner Posted at 2018-2-18 15:43
The idea depends on how well the 2.4 ghz antenna is made. If it's a dedicated 2.4 antenna, then yes, tilting would be silly and accomplish nothing.
I confess I cannot say for sure what a wave looks like when it's transmitted with a bad antenna. But there's also the receiving aspect of it.
An antenna is a tuned circuit, or should be if it is going to work efficiently, which means it needs to be a multiple or sub-multiple of the working frequency. The antennas on the P3 and P4 are 130 millimetres long, the wavelength of 2.4 Ghz is approx. 125mm, so this seems to correlate, as part of the length of the plastic shroud is probably not actual antenna. The wavelength for 5.8 Ghz is approx 51mm, which does not correlate at all, even for twice wavelength, because it should then be 102mm.
The basic principle of a whip antenna requires it to be a sub-multiple of the wavelength, so it would seem that DJI have chosen a full wavelength antenna design for 2.4Ghz, but an incorrect length for 5.8Ghz. It is possible to correct for an incorrect length by placing an inductor in the antenna to 'tune' it, but it would still not be correct for both bands.
I looked at the P4P manual, and it does specify 90 degrees antenna angle for 5.8Ghz, and 60 desgrees foir 21.4Ghz, but according to the theory I studied, this will have no effect at all on the transmission of a signal from the RC unit, and as far as I am aware, no effect on signal reception. Angling the antenna only serves to til the axis of the 'donut', which in my opinion, is not desirable. |
