trooper1
Flight distance : 26611 ft
We discovered that the maximum range we could set a waypoint, in the intel flight waypoint mode, from our home point, was 1,600', even after we found a setting to turn on max range. How can we set several way points more than 1,600' distant, assuming we're not just ignorant about how to use the waypoint smart mode? Would this method work: set a home point right under a desired waypoint pos - fly the P4 up - set the waypoint - land the P4 - while leaving the P4, IPAD, & controller on, drive to a new home point location a mile distant - repeat the process to create another waypoint above that new home point - drive to another home point a mile distant and repeat the home/waypoint process. Hit APPLY in the waypoint mode menu. Would the smart mode reject these waypoints and/or would it save the waypoint mission after shut all of the equipment down and power it up, like a day later? |
