Charger 3 batteries not charging 2 together
1660 10 2018-2-18
DJI_Mike
Poland
I have the fly combo of dji spark from Nov-dec 2017 everything have been good until the other day. I tried to charge the 2 batteries and I saw it can’t be possible. I had to charge one and then the other one. Do you know what happen or how can I fix this problem? Thanks!
2018-2-18
dj_dread
Flight distance : 648399 ft
Romania
The charger can charge 3 at once. Check if you put the batteries in the correct position.
Also, if the batteries are too hot, the charger will wait to reach the optimal temperature before charging them.
2018-2-18
DJI_Mike
Poland
Thank you I will try again. It’s strange. It could be cold problem also?
2018-2-18
dj_dread
Romania
It could be cold as well
2018-2-18
TudorD
Flight distance : 832480 ft
Romania
Sometimes if you press the button from the battery that is not charging can resolve this situation.
2018-2-18
DJI_Mike
Thank you, I will try also this. It is too strange, it’s working with one , not with 2 together
2018-2-18
Rustic17
Flight distance : 2733760 ft
Sometimes if one battery has more residual charge than the other, there will be a delay before the more fully charged battery starts charging.
2018-2-18
Leftyguy
Flight distance : 1282638 ft
I believe it only will charge one at a time in rotation.
2018-2-18
Rustic17
No...my three all charge simultaneously when they first start about the same charge level.
2018-2-18
SkyySpyy
Flight distance : 338222 ft
Happens to me when I try to charge 3 at a time. 2 will charge and one doesn't light up. I have to shuffle them around and tap the button and after some fiddling around they all charge. But it happens every single time.
2018-2-18
DJI_Mike
Poland
Thank you all for your answers. Finally I used my spark today and when I tried to charge the 2 bateries, it works. It could be the temperature too cold. Thanks again and keep flying the spark!
2018-2-25
