justin.rose
You can also run the GH4 on LB and then run your FPV through the 5.8ghz transmitter and use 2 monitors.
My current set up is the S1000, A2, Data Link 900 mhz, Lightbridge, GH4, Hero3+ for FPV and 5.8ghz video transmitter for FPV.
You have to run a micro HDMI cable direct from your GH4 to your LB air module which means you lose 360 degree gimbal control. Keep that in mind when making the decision to use LB. Running video feed through your gimbal to LB will result in a horrible image that is next to unusable. |
