RobertWSimpson
Flight distance : 927185 ft
Hi Solestacz
When I was putting the green cover back on the top, I crimped and almost severed the cable to the antenna. I thought about soldering it, but then remembered that it is coaxial, which makes that pretty much impossible, especially with such a small diameter cable. Rather than disassemble the electronics inside of the body to reach where the antenna is glued, I just adhered it to the outside in the same location. Luckily the new body came with new antennas, so I had a spare!
This antenna, by the way, is only in charge of video transmission. There is another antenna on the other side of the body that receives commands, so if for some weird reason this mod were to fail, RTH would still work.
Thanks for the comments! |
