WIFI power - FCC vs CE for the MAVIC AIR
11433 6 2018-2-19
fans4eb33ea9
Flight distance : 47418 ft
Hi
I connected my mavic air for the first time indoor in NYC but last time I used dji go app I was in Italy last summer. The location showing on the map
was still in Tuscany and the app gave me an alert that the WIFI of the mavic will reset to comply with that country.
Now, is it my wifi reset to a the weaker CE standards? I did fly in New York briefly today but I had not seen the same alert reverting the WIFI to FCC.
Where can I check it in the app? This is not related to the frequecy, only the power output, right?
Thank you and Ciao!
2018-2-19
Griffith
Flight distance : 98537 ft
Take your Mavic outside where it can get a good GPS signal.  Then it should correct automatically.
2018-2-19
cicciopilota
Flight distance : 36624 ft
If you have 11 channel in WiFi you are in fcc if more in ce
2018-2-19
Wachtberger
Flight distance : 261509 ft
cicciopilota Posted at 2018-2-19 14:04
Exactly, and if I knew a way (other than buying a flight ticket) to get the 11 channel in 2.4 Ghz I would go for it ;-)
2018-2-19
fans4eb33ea9
Great thanks! Yes I got 1-11 then 149 153 157 161 165
2018-2-19
djiuser_9iBdDMR28Xk8
Flight distance : 1944606 ft
Greece
there is a big diffrence between FCC mode vs CE mode in Europe
see this video
2018-2-26
Cor T K
Flight distance : 14144 ft
Remark:
Floater only works with Android phones. Not iPhone. If you have an Android phone beside you're iPhone you can use the Android once to change the region setting to change to FCC. After that you will always get the popup screen you have to change wifi settings always choose " NO" when you start up.
2018-2-27
