dicon.sp
Flight distance : 124505 ft
mecanique62 2 Posted at 2018-2-20 19:21
Here’s the post Jeff was talking about. OK, I finally fixed mine today (4 day ago). I connected my goggles through the USB connection & selected smooth mode, Then switched back to HDMI & it started working, pretty choppy though, so i connected USB again & switched to Normal mode, then back to HDMI & everything looks pretty good. I Hope this might help the rest of you. Oh, I forgot, I uninstalled DJI Go 4 & reinstalled thinking that might have been the cause, but it wasn't.
Hello mechanique62 2
As I mentioned to "Jeff Millard" in the post above, the module does not work for me nor connecting it only to the TV monitor, (without connecting glasses).
When I connect a device with HDMI output, (DVD, PS4, etc.) to the TV via its cable, I press the "source" key on the TV remote and a menu appears on the screen highlighting the source I have connected, indicating that an HDMI signal is coming in, and I simply choose it and from that moment the HDMI equipment that I just connected plays the content on the screen.
In this case, when I connect the RC station with its corresponding cable to the TV, and press the "source" key on the remote control, no HDMI signal on the screen will be highlighted to be able to choose it, which indicates that no HDMI signal is coming.
As commented "fabrizionannini" in the other thread, I have also checked that the module is well connected (as seen in the images of my first comment), and that the latest updates are installed.
I can not do the same test as you since I do not have glasses to connect, but I think that connecting the iPad to the USB output type "A" to receive the signal from the RC transmitter, and the HDMI output to a monitor with input HDMI, it would have to work and you would see the image on the TV.
Another detail that I have seen, is that the microUSB output type "A" (which would have to do the same job as the "USB output type" A ") does not work either.
Greetings and thanks for the contribution |
