Does anybody not have focusing issues with Osmo +?
1786 6 2018-2-19
Lwgray 0
Malaysia
If you don't have a blurry infinite focus or a wandering Auto Focus issue, can you tell me what you're doing to set these?
Callibration on mine still gives me a soft infinite. And auto-focus needs a lot of screen tapping to maintain the focus.
Moving shots seem to be very problematical and since the camera is supposed to be for smooth tracking, not being able to maintain focus under those circumstances seems to be something of an issue.
So, what settings and what circumstances work best?
2018-2-19
DJI Elektra
Hi, there. What is the firmware of your Osmo +? I would recommend you update to the latest firmware and calibrate the lens. Thanks for your support.
2018-2-23
Lwgray 0
Malaysia
Firmware version 1.6.1.0
I calibrate the lens and Infinite is always softer than AF.
2018-2-23
FarmerMac
Flight distance : 1215079 ft
Denmark
I got the focus issue on my brand new Osmo+
Tried different settings and both AF and Infinit focus. None of them give me
that crispy sharp picture i thouth this device could deliver.
Tried the lens calibration too..
Is there any kind of work-arround to solve this problem. Firmware downgrade
or things like that? Im on the latest version right now.
Kind regards
FarmerMac
2018-2-23
Lwgray 0
Malaysia
FarmerMac Posted at 2018-2-23 06:12
I have a similar experience... though it sometimes works sometimes doesn't.
I can't help feeling that when one moves, the lighting conditions can change and that the depth of field alters, thus throwing it in and out of focus. Though, given the bright sunlight of where I live, one wouldn't expect this issue. Certainly, if you use the zoom to reduce the width of angle, it is very hard to keep it focused and that must be to do with reduced focal depth.
I'm trying to keep an open mind about it as there is a learning curve with using this camera. It behaves unlike any other camera I've had. And it might be the case that, what is useful as a drone camera, is perhaps not so useful for trying to replicate steady cam rigs with video cameras built for more versatile usage.
2018-2-23
djiuser_D4zchqgTBndc
Flight distance : 33435 ft
Has anyone found any literature or direction online on how to use the green Auto Focus box properly? I have so many questions related to that function! Share if you have any sort of instructions, thanks!
2018-3-3
LensmanDave
With the green focus box active, you have to tap the screen where you want the Osmo to focus. If you have a subject that is changing it's distance, the Osmo WILL NOT track the focus automatically. You will have to keep re-focusing by tapping the screen. A bit like 'pulling focus' with a professional cinema camera. The only time the Osmo will 'auto focus' is at the end of a zoom change.
2018-3-3
