FlyingFish82
Flight distance : 3662503 ft
Rob Hulford Posted at 2018-2-23 08:47
[view_image]
There is some unusually cold weather heading to the UK next week, will this be too cold to fy, i.e despite warming the battery will the air chill it to a point that it cools down to quickly ? Forecast to be a moderate breeze too.
i have personally never flown in Temps colder than -10 C, the issue there too is the battery life of your mobile device. such cold weather can significantly drain the battery.
what i would do is pre-warm the batteries with the hand warmers, fire up the mavic and let it running for abpout 1-2 min with props spinning on the ground, take off slowly to about 1 meter height and hoover there for about another minute and check all the controls and inflight status, do a couple of left/Right, back/fwd, up/down test on the controls to make sure all systems are properly responding, and then if everything worked , lift off gently on the throttle and fly with VLOS (visual line of sight) this way if you see any unexpected behavior you can bring it back manually seeing it (avoid flying over property or people as well).
hope you have a safe flight! and let us know how it went!
cheers! |
