Question re Pink flash in video
687 12 2018-2-20
Rappo
Flight distance : 387 ft
I experienced something odd in a couple of videos I made with my Spark and was wondering if anyone has seen this before.
Full disclosure......I'm a first time poster, completely new to filming with a drone and equally new to editing. I haven't purchased an editing program, been trying to use Imovie for now. Using video from the Spark, I also added a few stills from my phone camera (LG G5). Frequently during playback, momentary pink flashes can be seen in the section of the clip where the photos were inserted. I am attaching my first Spark video that illustrates this. The first flash can bee seen just after the :50 second mark (cactus close up) and also after the 1:50 second mark (2nd cactus close up). I realize this isn't a Spark issue, just hoping someone with more experience than yours truly might be able to offer some guidance. Thank you to all.
2018-2-20
Sidd Finch
Flight distance : 256 ft
looks like you might have a space in your time line between the video and the still. see if you can zoom into the timeline of the video editor and check for a gap between the video and the still image. It could also be the transition you are using. Check to see if the transition is using some default color that is not black.
2018-2-21
RobertWSimpson
Flight distance : 348881 ft
Also make sure that you are using the correct framerate.  If you are recording in 30fps but editing and uploading in 24fps, some of the interpolation could get screwy.  Just a thought.
2018-2-21
Rappo
Sidd Finch Posted at 2018-2-21 12:32
I'll give that a try and see what happens. Thanks for tip!
2018-2-21
Rappo
RobertWSimpson Posted at 2018-2-21 12:37
Its seems like the only issue is with the photos inserted into the video. Not sure if iMovie allows for control of frame rate though I will check. Thank you!
2018-2-21
RobertWSimpson
Wait, did you insert pink photos into your movie? You did, didn't you.  You did.
2018-2-22
Raimenzio
Flight distance : 237057 ft
Republic of Lithuania
It's a definitely editing software glitch. You get those pink flashed where the video fades out, what you can try is loose the transition in video and see what happens. Nice video thou.
2018-2-22
Rappo
Raimenzio Posted at 2018-2-22 10:54
Thanks for the tip my friend. I'll give your suggestion a try and see how it goes. Thank you!
2018-2-22
Sidd Finch
Can you tell us what transition you are using in imovie?
2018-2-22
Rappo
I'm using Cross Dissolve in Imovie
2018-2-22
djiuser_Ege9jYMrFSkh
Flight distance : 1296 ft
You may want to look at a video editor that is just a bit more advanced. I've been using "VideoMeld" for years, it's not expensive and is easy to use. Yes, you can control the frame rate, do dissolves and everything else I have ever wanted to use.
2018-2-22
Rappo
djiuser_Ege9jYMrFSkh Posted at 2018-2-22 16:41
I agree. I'm discovering some of iMovies limitations. As poster Raimenzio suggested, I removed the transitions from the video and the pink flashes went away! Transitions  can add so much to the finish product that I hate to give them up. I'll look into Video Meld. Thanks to everyone for helping me sort this out.
2018-2-22
CharlieZ
Flight distance : 314862 ft
Cool, thanks for sharing!
2019-1-8
