Hi, please could you put it to the DJI Go 4 team that a set of UK units would be most appreciated, MPH and Meters, this could be just for us that have or own weather statin here in the UK but i am sure i am not the only one that preferes my distance to be in M (meters) and my speed to be in MPH (miles per hour)
In the UK, we normally measure airspeed in knots, and a UK weather station should be measuring wind speed using either knots or meters per second. Why would you want a mph option?
I think it is much easier to learn to use km/h, makes far more sense when using meters for other measurements. Why would you set altitude and distance limits in meters and then measure distance in miles! Miles are only for road signs
The units that should have an option for change is altitude since aircraft all over the world use feet for measuring height / altitude and it is feet that are in the regulations. Our Drone Code recommends we stay under 400ft but the Go App displays meters and the limit is set in meters.
Personally I prefer to stick to meters, Km, m/s and km/h.
Geebax Posted at 2018-2-20 22:05
Great idea, I want an Australian one with distance measure in Poofteenths and speed measured in Furlongs Per Fortnight.....
Oh i havent laughed so hard in such a long time what a crack up
Nigel, that would be all well and good if it was airspeed but its not ;)My stations primary unit is knots, it adjust to show the unit i want, also uk forcasting media uses mph
The uk measures rain in mm yet we do not use kph for speed.
My weather stations measure wind sped in both. Why? Because I am one of those old farts who knows what a 20 mph wind should be but knots is, well, a bit more knottier, to judge. I will freely admit it is an old person thing.
Standard is MPH in most media for the UK and im referring to the land not sea ;)
In UK weather stations its quite common for us to us the MM, MPH, ºC and Meters for height, eg anemometer at 10m high,
There are some weather apps that have a UK setting for the units i have mentioned, Dark Sky is one of those another is YoWindow
Just to add, if such was ever implemented, it wouldnt mean you would have to use it, i was requesting it for those that feel it would benefit, i for one certainly would, KPH and Meters is not ok as UK uses MPH, MPH and FT is not ok for me cause i prefer Meters for distance, its ok if you are good at maths but i most certainly aint, nor English lol
