DJI Thor
Flight distance : 13602 ft
Hi there, the height will be limited to 5 meters when there is no GPS signal and VPS engaged, 30 meters when the VPS is disabled. It is not able to change the limit, but pano modes should be available when flying without GPS. You can try to disable the downward system on the app to reach a higher altitude. Hope it helps.
