New Davinci Resolve 14 is out FREE version
11889 18 2018-2-21
Jos A
Flight distance : 73209 ft
Professional color and editing tool for post production
New version is out, you can download free version free version
what's new
DaVinci Resolve 14 has hundreds of new features for editors, colorists and now, for the first time, audio professionals. The new playback engine dramatically increases responsiveness with up to 10x better performance for editors. You also get a whole new page with the full Fairlight audio post production tools that let you record, edit, mix, sweeten and master sound with full 3D audio space and up to 1000 channels. Colorists will find amazing new Resolve FX that include automatic facial recognition and tracking for quickly smoothing skin tones, brightening eyes, changing lip color and more! Plus, DaVinci Resolve 14 features revolutionary new multi user collaboration tools such as bin locking, chat and timeline merging that allow editors, colorists, and sound editors to all work on the same project at the same time! All these new features make DaVinci Resolve 14 the world’s most advanced post production software
2018-2-21
rantanlan
Flight distance : 69698 ft
Wasn't this released in 09/17?
2018-2-21
Jos A
version 4.3??? whole new page with the full Fairlight audio post production tools that let you record, edit, mix, sweeten and master sound with full 3D audio space and up to 1000 channels ????
2018-2-21
LoSBoL
Flight distance : 666483 ft
Free sounds good    Is there a steep learning curve in using this software?
2018-2-21
Jos A
yeah look on youtube at Casey Faris, or look at this
2018-2-21
LoSBoL
Superb!  Thank you!
downloading...
2018-2-21
Cameleon
Flight distance : 60394 ft
Hmm. think I'll give this a look later. Was looking at using Resolve to edit videos.
2018-2-21
Jos A
Its a good program
2018-2-22
xfirf_
Flight distance : 194911 ft
Actually that was already available before.
14.3 is mainly a bug fix release:
What's new in DaVinci Resolve 14.3
Added support for the Blackmagic Design URSA Broadcast camera
Added support for RAW footage from the Sony Venice/CineAltaV camera
Improved the quality of thumbnails in the Media Pool and Edit page timeline on retina monitors
Added support for reading Panasonic Varicam metadata when importing footage
Added support for exporting Sony color space and gamma metadata when encoding to MXF
Added support for RED SDK v7.0.6
Addressed an issue where the audio section in the Deliver page would default to timeline track instead of the Main bus
Addressed an issue where editing a transition could sometimes cause a crash
Addressed an issue where syncing video to audio with a different sample rate results in incorrect audio sync and pitch audio
Addressed an issue where changes to the Mixer UI layout would not get saved in a dual screen setup
Addressed an issue where pressing arrow keys to move volume keyframes would not work after opening the keyframe curve editor
Addressed an issue with the option to pick which node to select when switching clips
Addressed an issue where a project would fail to save after deleting a group
Addressed an issue where a project would fail to save after specific undo/redo operations
Addressed an issue with UI artifacts in the DaVinci Resolve Studio activation window
Addressed an issue where projects with LUTs would not get exported correctly on Windows
Addressed an issue where the current project could not be copied between databases
Addressed an issue where relinking to TIFF files with a higher bit depth would result in a crash
General performance and stability improvements
2018-2-22
Montfrooij
Flight distance : 2560453 ft
If I am correct the free version does not allow for 4K editing. But I'll look it up.
2018-2-22
Montfrooij
Hard to find, but here it is.
The free version of DaVinci Resolve has all of the professional editing, legendary color correction and Fairlight audio tools you need for SD, HD and Ultra HD work at up to 60 frames per second. DaVinci Resolve Studio adds support for 4K and higher, along with frame rates up to 120 fps. It also includes dozens of additional image processing features and filters that are not in the free version. This includes film grain, temporal and spatial noise reduction, amazing new face enhancement tools, lens flares, lens distortion correction, optical quality blur and mist effects, match move, warping and much more!
So only the paid version allows for 4K editing.
2018-2-22
xfirf_
I think exporting only works in 4K with the paid version, but downscaled 1080 will be possible.
2018-2-22
Bob Brown
Flight distance : 4209662 ft
Love this software. Just make sure you have at least 16GB ram and a good CPU / video card.
2018-2-22
Little John
Flight distance : 192244 ft
Thanks I’ll take a look
2018-2-22
Montfrooij
xfirf_ Posted at 2018-2-22 11:24
Yes, only Ultra HD on the free one.
2018-2-22
Mark Blaide
Flight distance : 246014 ft
I have the free version and I can load a 4k video and output it to 3840x2160 ultra hd. This is 4k according to Wikipedia.
2018-2-22
Cameleon
4K (projection standard) is 4096 by 2160 pixels
UHD (TV standard) is 3840 by 2160 pixels
So they are different but unless you are mastering footage to be shown at a cinema then UHD/2160p is fine
2018-2-23
LKHPhotography
Flight distance : 952133 ft
would like to hear more from current users, especially its comparison to Premiere Pro in terms of usage, convenience, hardware requirements, using difficulties, etc. ???
Thanks in advance!!
2018-2-23
Jos A
work in version 14 also
2018-2-24
