Nillok
Flight distance : 51585 ft
Peterev Posted at 2018-2-22 15:56
The video that Nillok posted shows the Air at a reasonable distance away from them, I see no reason why it shouldn't work at that distance, it's certainly much further away than the 6 or 7ft you first mentioned.. If it is an altitude rather than distance issue perhaps turning off the downward sensors might have an effect, I'll try that at the weekend too.
I will try some following the upcoming week without obstacle avoidance and see if that helps. I'm happy thou I did not have the double altitude when I tested it, if you stick to the end around 6:45 in the movie you will hear an incoming low sniffing helicopter at approximately 100m |
