stuka75
Flight distance : 85682 ft
Many video downfeed issues come from phones/tablets with both litchi and Go on them. You must force close either app prior to using the next. I have found even between/flights on same day, with different battery poor to no video feed unless I turned off the tx, ac and force closed the app. Either Go or Litchi. This is in Android devices of course. The apps dont always work smothly if both are in mmemory at same time. Force closing app via the settings/app/Lithci or Go many times will fix this issue. Before tearing your controller apart, or changing fimrware, make sure your startup protocol/setup is not the problem by always:
1. Force close both apps, Go and Litchi.
2. Turn on Controller
3. Turn on the AC
4. Open either Go or Litchi.
IF this fails, then try deleting the app, lefto over folders, and re adding the app to yuor device.
Always try the above first and ruling them out before going more invasive.
Good luck.
