Unstable video? - Need Input
801 15 2018-2-22
Crazyant
Flight distance : 852392 ft
Switzerland
Hi all. I notice some potential video instability/vibration/shaking issues with my Mavic Air (I say potential because maybe it's just me over-exaggerating) . Here is a test video I made . DJI routinely asked me to send it in to check it out. Before doing so, could you guys let me know if you notice any gimbal issues in the vid? Does the video look fine in regards to gimbal stability?
Thanks.
2018-2-22
the0bone
Flight distance : 11896 ft
I can't really see something.
But where do you have such landscape in the Netherlands? ;)
2018-2-22
QuadKid
Flight distance : 482349 ft
Looks Rock Solid to me, couple of spots have a tiny up/down movement but it doesn't look like a gimbal issue just a small movement when braking, perfectly normal IMO.
2018-2-22
Crazyant
Switzerland
the0bone Posted at 2018-2-22 01:50
haha not Netherlands buddy. Switzerland.
Regarding the "issue", don't you notice the video going a bit "bumpy" especially when breaking?
2018-2-22
Crazyant
Switzerland
QuadKid Posted at 2018-2-22 01:59
Yes, its during breaking mostly. Now you make me think of not returning it.
2018-2-22
Tadango
Flight distance : 232359 ft
Looks a bit higher than the Hondsrug
EDIT: Around 2:50 you see some "unstable" footage but that is normal when you brake. Try the cinematic mode to reduce that.
2018-2-22
M2Wair
Flight distance : 1192231 ft
It's normal, if it's not broken don't try and fix it.
Adjust your settings and try again by Following the steps highlighted in the thread below and you'll be silky smooth.
https://forum.dji.com/thread-135218-1-2.html
2018-2-22
Crazyant
Switzerland
M2Wair Posted at 2018-2-22 02:13
Reason why I got worried a lot was because when I had to unscrew the lend cap for to add the ND filter, let's just say that things were more tight than usual. Had to apply a lot of pressure to unscrew it.
2018-2-22
M2Wair
Crazyant Posted at 2018-2-22 02:16
Right, I get it now. I guess it would worry us all and I too would have the "I broke it thought" lol. Hopefully it will be fine and you can continue flying without worry.
Keep us informed.
2018-2-22
Crazyant
Switzerland
M2Wair Posted at 2018-2-22 02:39
Keep us informed.
So you still think nothing is wrong with it?
2018-2-22
FlyDK
Flight distance : 1636286 ft
Denmark
It's perfectly fine to me.
2018-2-22
M2Wair
Crazyant Posted at 2018-2-22 02:52
Yes, it looks fine, just follow the instructions on the thread I posted and it will be silky smooth
2018-2-22
Crazyant
Switzerland
M2Wair Posted at 2018-2-22 08:14
OK, too bad it's snowing now to test
2018-2-22
kfloke
Flight distance : 149961 ft
Singapore
Perfectly normal to me
2018-2-28
TroutboyNZ
Flight distance : 1726486 ft
New Zealand
Dial down your sensivity in yaw and also the camera gimbal settings and brake, makes a huge difference, from factory the settings for film work are super aggressive.
2018-3-1
Jos A
Flight distance : 73209 ft
Dit is normaal,
probeer dit eens
Gimbal Settings :
Yaw Movement Limit - 35Max
Gimbal Pitch Speed - 9
Extend Gimbal tilt Limit - Yes (to tilt up)
Gimbal Pitch Smoothness - 19
2018-3-1
