shivamsharma
Flight distance : 2149 ft
S.J Posted at 2018-2-23 00:07
At 22 meters height , this much damage, its against laws of physics !!. I had my drone fall from 80 meters high 3 times may be 4 times but still it works pretty well ! But of course each time the props were working in full upward thrust as it fell .
Were you flying in SPORTS Mode while this happened. Did you see a obstacle during your flight ? On what ground surface material did it hit ?
Hi SJ,
The drone dropped flat from 22m (That's about72ft) on a tarmac surface, try throwing your drone again from the 7th floor and we'll try to match the damage. As I mentioned, the propellers stopped moving at that height and it went straight down. In your case, props were working, that's the fundamental difference.
Also, as mentioned in my initial post, it was in Tripod mode with 0 obstacles. |
