DJI_ALEX
Flight distance : 4915053 ft
StanfordWebbie Posted at 2018-2-22 09:20
Could be a whole bunch of things. First, did you read the manual? Often times, the problem is due to not setting something that the manual said was needed. Second, you never mentioned the size of your SD card, nor whether you had formatted it. Finally, have you gone through all your settings and understood what each one meant?
Yep, I understand it all I think. Using a 64GB San Disk Extreme Pro so it should be all good.
All formatted correctly.
Anything that springs to mind StanfordWebbie? |
