fanse7cef96d
Flight distance : 2859921 ft
Qatar
DJI Thor Posted at 2018-2-23 00:48
Hi there, normally, Qatar applies CE mode, and Mavic Air supports max to 2000 meters in 2.4GHz on CE mode. For your case, please ensure that the antennas on the drone are fully unfolded, check if the current channel is on 2.4GHz, select a channel with less interference. Flight distance sometimes relates to the flight environment; please fly the drone in an open wide area, please make sure the remote controller’s antennas are positioned parallel to and are pointed towards the aircraft; update your drone and RC to the consistency or latest version. See if it helps. [view_image]
well I do everything you said always, but you have to get feedback from dealers from the middle east everybody is complaining from signal lost there I know hundreders of drone pilots sold there mavicair because they cant enjoy it ..this is something you have to look for
