luciens
Nigel_ Posted at 2018-2-25 01:35
I think it is only flight distance that is improved with airspeed, not flight time. If you want to fly as far as possible on 1 battery then fly at ~30mph airspeed, but to fly for the longest time it is probably atti mode and drift with the wind. I've never seen anyone confirm this though?
As for maximum airspeed at high altitude, I wouldn't be surprised if it was less than at low altitude because although there is less air resistance to overcome, the props are going to be almost maxed out just overcoming gravity which means it wont be able to get much in the way of tilt angle so it can't put much power into horizontal speed, plus the props don't have much air to pull on.
Agree. In general, max endurance, max distance possible and max airspeed possible aren't going to be the same airspeeds and power settings. Which is which will just depend on the conditions, wind and so on.
As for max airspeed at altitude, I also agree - the maximum power available (to produce thrust) will be the main limitation. I suppose if you qualify it with "all else being equal", the true airspeed will, in general, rise with altitude and the lowering density of the air.... |
