djiuser_1bZfdd2y53AK
Hello, I had the same issue (telem freezing when armed, resets when not), this can be fixed by turning off telemetry in the betaflight configuration menu, counterintuitive i know. If the telemetry only works when the quad is off, and stops when it is armed, that's the reverse of how telemetry is supposed to work. I also set a manual baud rate at 57600 but that will depend on your board & version & software used (e.g BF). Running latest firmware on both goggles as of today (5/7/18). running BF 3.3.0
Hope this helps anyone else who's struggling to run telemetry as i was. Same issue can be replicated if the telem works whilst plugged into a pc, but fails when not plugged in.
