Motor Noise Fix?
Carson22
Flight distance : 98 ft
My Phantom 3 Pro's motor sounds like there is some sand it in. When I spin it it sounds gritty and abnormal. If someone can tell me if I need a new motor or how I can fix it that would be great. I have opened the shell and cleaned and blown out everything with air. Sometimes when I spin them they'll get stuck and then break loose again.
2018-2-23
DEUCEDOG
Flight distance : 2501575 ft
That's not good , i presume if you blew out the shell you also blew out the motors ? , there may be debris trapped so if it were mine i would change them all  ( for what they cost ) just to be on the safe side .
2018-2-23
Carson22
DEUCEDOG Posted at 2018-2-23 11:56
I did blow out the motors as well. How easy are the motors to change. Does it require soldering?
2018-2-23
DEUCEDOG
I have not changed motors myself but i believe it its straight forward and does require soldering  , if you are in  doubt  you could send it back to DJI for a quote ?
2018-2-23
Peo
Flight distance : 25409177 ft
Sweden
Keep in mind that small iron particles may enter the magnet of the engines.
2018-2-23
DINGO DOWN UNDA
Flight distance : 3058816 ft
Carson22 Posted at 2018-2-23 12:11
Plenty of videos on youtube for motor change.
2018-2-23
RicardoGray
Flight distance : 4356421 ft
Motor replacement is not hard. Yes, you need to solder though. You need a good iron, one that gets hot enough to remove the existing wires fairly quickly. You don't want to have to hold the iron on the mother board for an extended period of time, to keep from damaging something else. Remove the wire from the main board is easier than splicing the wires as far as I concerned. I have done probably motor replacements on 5-6 phantoms now. The motors are cheap, around $18-$20. I would replace them all if it was me.
2018-2-23
DJI Elektra
Carson, please shoot a video about the situation and I would forward it to our engineers for further check.
2018-2-23
adam
Pakistan
It is recommended to change the motors to prevent any crashes due to a mid flight motor failure.
You can check our website for replacement parts.
Adam - Technical Advisor at Dronerr Parts, the place to buy all your drone replacement parts.
https://Dronerr.co.uk
2018-5-27
KedDK
Flight distance : 1133038 ft
Denmark
adam@dronnerparts Posted at 2018-5-27 07:00
Who on earth would lay their trust of getting their gear repaired of someone who can't read and begin waking up old threads all over just for the advertise itself!
2018-5-27
Dronerr Shop
Hi,
I am really sorry about this, I had hoped to employ someone who could be genuinely helpful on the forums and help raise brand awareness for our company, so I decided to do a trial of someone who seemed very knowledgeable about drones in the hope that he could answer people's questions and that eventually people would become aware of our company, but I didn't want any hard advertising like this and I also asked him to do it on the Phantom pilots forum rather than this one as you can add a short signature there, which is not against the rules.
I can assure you that I will not be hiring him again as this has had completely the opposite effect - he wasn't helpful and it makes our brand look bad. I have asked him to delete the posts and I am extremely sorry for any inconvenience caused.
Best wishes
Olly - CEO at Dronerr.co.uk
2018-5-27
Carson22
Dronerr Shop Posted at 2018-5-27 09:34
Hi,
Don't need help anymore. I just went for it and it worked. I turned the drone on and prepared for flight and and hovered and the small gravel and debris flew right out. I landed back down and then hand turned them and there were no more noise
2018-5-30
Joszhe Tosa
adam@dronnerparts Posted at 5-27 07:00
Read your disclaimer post and mea culpa after this but blaming it on an employee? SMH
2018-12-24
solentlife
Flight distance : 1087530 ft
Latvia
Carson22 Posted at 5-30 11:30
Nice one ..
Even though this will cause some to post that its all BS ... I can assure it is not.
I have in the past unbolted the motors one by one ... (I make a small mark to show which was first) .. Turn AC upside down and have motor tilted slightly so I can get a toothpick and a drop of very light sewing machine oil onto the shaft bearing area. Spin by hand .. then right way up and bolt motor back. Move to next one and so on...
The motors do NOT have sealed bearings ... they are SHIELDED bearings. This means that the oil DOES wick in and DOES not create any problems as some claim.
This is actually a common practice for many RC users of Brushless motors ...
OK - about debris .. the general BL motor being unpluggable can be 'washed' even in fresh water to remove debris. But if the debris is ferrous or trapped between magnets - this is a problem that needs care. Usually dismantling motor to clean the inside of the bell. DJI do not make it easy in the motors they have bought in ... and of course the hardwiring in.
just mentioning ...
Nigel
2018-12-25
