Phantomflyer
Flight distance : 1016486 ft
Thatguy32567 Posted at 2018-2-24 04:11
It is the Phantom 4 Pro. The firmware on the drone is 01.05.0300 and the firmware for the remote is 1.3.6.0. I took it out yesterday and it did not do it. It was very cloudy though so not sure if what geebax mentioned could be the problem with the sun. I did notice however that the camera will invert the image. Not usually when the camera is pointed down but instead if I'm flying forward fairly fast then let off the controls. When the drone stops, the image inverts for a second or two then goes back to normal.
If I'm not mistaken, I don't believe you have updated to the latest R/C Version. I'm not entirely certain if this will affect your model in the way you have described, but I know I'm on R/C version 1.4.01 which may not be the latest, but I believe may be a later version than what you have.
Reports of inverted picture have been reported when some have updated to A/C firmware V. 1.5.300, however, I don't recall reports of obstacle sensor issues with that specific F/W update.
Hopefully DJI will have some better information for you. |
