PUMMY
Flight distance : 376450 ft
Another fan, failing on a Mavic Air.
Background:
1) Under 1 hour of flight time
2) 4 battery charges flown
3) No hard landings or crashes ( Flight records are all synced and show no impacts or hand caught landings )
Tried...
1) Factory defaults restore via DJI Assistant 2
2) Firmware reinstall of the current version, using DJI Assistant 2 (Saw a link where install of old firmware then to new worked, but I don't know the process)
3) Compressed Air clean, through the vents using a low pressure compressed air can (Ensuring no liquid was present before apply into the aircraft)
Case has been raised - CAS-1495157-Y5C4G1
@DJI Admins, there is a repair centre a few miles from my current location, would you consider allowing this centre to perform the investigation?It is not clear if UPS EU will pick up the package or if I need to send it at my own cost. Can you please look at your repair webpages and see if you can confirm when the address is entered, if UPS will be able to pick up from the address or not? Should be easy based on country and zip code of the address.
My thoughts?
1) Aircraft has no filtration mechanisms availble to prevent debris from entering into the fan mechanisms, causing to a mechanical failure
2) High rpm fan may fail when less than gentle input corrections are encountered and the bearing / support is not designed to accomodate this
3) Software bug - Not sure how this would happen, but others seem to of been able to get this fixed using firmware updates.
Points for DJI to consider
1) Hard shutdown the aircraft to prevent the logic board from cooking and causing even more damage
2) Review how the air enters the aircraft to allow cooling to take place, and look to change this to actively prevent debris entry?
3) For the design engineers in a later update - When connected via USB to a computer, shutdown the GPU / CPU / camera components BY DEFAULT, so that only the items required for the aircraft to communicate with DJI Assistant 2 are enabled and powered on - If you have a cable attached to the craft, you can disable the obstacle avoidance GPU's and prevent power to the ESC's, as well as limit gimbal power since you are connected to a computer.4) Can you please review how the gimbal motors can be powered down, when the protector is attached? New flyers can and will forget to take the cover off. If you can detect this, maybe post a warning to check the gimbal cover has been removed, as well as saying "gimbal motor overloaded"
