Panorama
1313 28 2018-2-25
yoni
South Africa
How do I do a panorama if it isn’t showing up once I fly
2018-2-25
Wachtberger
Flight distance : 261509 ft
You have to open the camera menu and choose which one you want to use:
2018-2-25
Montfrooij
Flight distance : 2560453 ft
Are you still in beginners mode?
2018-2-25
yoni
South Africa
No I’m not in beginner mode but it’s there before I take off but once I take off it doesn’t show up
2018-2-25
A CW
Flight distance : 13838848 ft
Do you have an SD card inserted and successfully formatted before take off?
2018-2-25
Wachtberger
yoni Posted at 2018-2-25 12:11
This is weird. Look at the screenshot below. Are you sure that you are in photo mode (upper green circle) and then click on the camera menu (lower green circle)?
2018-2-25
yoni
South Africa
Do you have to have an SD card
2018-2-25
fanse5394b5d
Flight distance : 128471 ft
yoni Posted at 2018-2-25 20:39
Did you "Palm Launch" your spark.
If so you can only access single shot in flight.
Switch to normal control once in flight and all camera modes are available
2018-2-25
yoni
South Africa
How do you do that
2018-2-26
yoni
South Africa
Can someone please tell me how I can change back to normal control
2018-2-26
yoni
South Africa
I can only access single shot at the moment
2018-2-26
fanse5394b5d
yoni Posted at 2018-2-26 12:42
Read the manual.
You should not be flying if you do not know how to change between the different flight modes.
Look at the screenshot in response #6 of this thread
Left hand edge, 3 icons.
Top to bottom they are take-off, RTH, flight mode.
Touch the flight mode icon, a new screen will open giving you access to flight modes. Select the one you want. ( the one showing in response #6 is for normal control)
But PLEASE, read the damn manual before you try to fly
2018-2-26
yoni
South Africa
It doesn’t say that in the manual
2018-2-27
fanse5394b5d
yoni Posted at 2018-2-27 10:50
It does in my copy
2018-2-27
yoni
South Africa
Ok thanks so much for the help
2018-2-27
fanse5394b5d
yoni Posted at 2018-2-27 20:44
Follow the instructions in response #12
You will then be able to select between the various flight modes
2018-2-27
yoni
South Africa
#12 in where
2018-3-1
yoni
South Africa
Do you think you can screenshot each move I must do to make to normal control as it doesn’t say in the manual I read
2018-3-1
fanse5394b5d
The 12th response in this thread
2018-3-1
fanse5394b5d
Look at the screenshot in response #6 of this thread.
2018-3-1
Hddeuce
Flight distance : 128261 ft
https://dl.djicdn.com/downloads/ ... 20Manual%20V1.6.pdf
2018-3-1
fanse5394b5d
That version of the manual is out of date and refers to an earlier version of the DJI GO4 app.
If the original problem of being unable to access panorama mode is due to palm launching Spark, then try doing what I said in response #12 of this thread.
To be honest if you can't follow those simple instructions, then maybe drone flying is'nt for you.
How about paper airplanes?
2018-3-1
yoni
South Africa
So are you saying that I must just give up
2018-3-2
yoni
South Africa
Fanse you know you sent that message about the 6th one on flight modes isn’t that gesture control
2018-3-2
yoni
South Africa
Gesture mode
2018-3-2
fanse5394b5d
Yes, if you palm launch the Spark it defaults to gesture mode.
In gesture mode the camera will only take single shots.
Once airborne use the instructions I gave in response #12 to change to normal flight mode.
In normal fight mode all camera options are available, including panorama.
2018-3-2
Hddeuce
fanse5394b5d Posted at 2018-3-1 23:19
You are saying version 1.6 is out of date?  Then please link to a more recent one as this is directly from the DJI website and I was referenced to this one by a DJI forum mod.
2018-3-12
fanse5394b5d
Hddeuce Posted at 2018-3-12 12:36
All the manuals reference an out of date DJI GO 4 app, they don't update that section.
If you still cannot access panorama modes, do not palm launch your spark. Put it on the ground and use the auto take off function, then your spark will be in normal flight mode and all camera modes will be available to you.
2018-3-12
Ahmad Najmuddin
Malaysia
Tutorial video solution for panorama stitching error..
2018-4-23
