New Mavic Air - Firmware update freezes - grounded :(
3652 21 2018-2-25
samflies
Flight distance : 4360 ft
New Zealand
Hi Folks
I got an awesome surprise from my wife yesterday for my birthday, an awesome DJI Mavic Air. Unfortunately I am still not airborn.
After unboxing and charging the batteries I fired the drone up and connected via the DJI GO 4 app, it alerted that it needed a firmware upgrade. It downloaded, transmitted and then started to install 'Aircraft Firmware: v01.00.0200' It froze on 83% complete and after leaving it for over an hour it never moved. Since then I've tried restarting the aircraft and controller a dozen times or more. It always freezes at 83%. I've also tried reinstalling the app.
I've tried to update the aircraft via the DJI Assistant 2 software on both Mac and PC, it gets stuck every time on 76%. I've connect just the controller to DJI Assistant 2 and that has updated fine but the aircraft itself appears to be bricked on arrival. I've reset the factory settings via Assistant and it still freezes at 76%, but now the Go 4 app will not even start upgrading and just errors out. It will not let me fly without updating. I've tried everything mentioned on the forums, this seems like a common issue. Any help very greatly appreciated. Really looking forward to getting this bad boy in the air!
Many thanks for your help
2018-2-25
riot!
Poland
I had same issue. Try to connect to wifi or reset the router.
2018-2-25
samflies
New Zealand
riot! Posted at 2018-2-25 01:16
Thank you most kindly for the idea. I gave this a whirl and no luck. For some reason now Assistant no longer recognizes the drone at all. Doesn't come up as an option. Not sure if this is to do with rebooting the wifi or just a co-incidence. The remote still connects fine. Go4 still doesnt want to even start the update, it says its not connected to the aircraft (but lights are all green) . Thanks anyway for the suggestion.
2018-2-25
samflies
New Zealand
Hi DJI Support - any help please? Still no change after countless attempts. At a suggestion I tried installing an SD card, no help. My support ticket has is being ignored. This sounds like its a common problem.
Any help very greatly appreciated. I'm looking out into the skies and daydreaming of flying!
Cheers
2018-2-27
Wachtberger
Flight distance : 261509 ft
samflies Posted at 2018-2-27 12:27
Cheers
Have you already tried with the latest version of DJI Assistant? There has been a new one on 24 Feb: https://www.dji.com/mavic-air/info#downloads
2018-2-27
davidmartingraf
Flight distance : 106566408 ft
Did you call DJI Technical Support?
2018-2-27
samflies
New Zealand
Wachtberger Posted at 2018-2-27 12:44
Thanks Wachtberger. Yes I've uninstalled and reInstalled DJI Assistant several times now. Including in the last couple of days, but that you most kindly for the suggestion. I'll give it another try just for the hell of it.
2018-2-27
samflies
New Zealand
davidmartingraf Posted at 2018-2-27 12:48
Thanks davidmartingraf - no I haven't as yet. I've tried an email ticket and online chat. Neither have been much help. The email channel is deathly quiet and the online chat fellow just told me to send it to a service centre. As I'm in New Zealand that's not very easy (or cheap). I'll take your advice and give them a call. Many thanks!
2018-2-27
Wachtberger
samflies Posted at 2018-2-27 13:13
I wish you good luck!
2018-2-27
davidmartingraf
samflies Posted at 2018-2-27 13:17
Don't they offer you an RMA with shipping label?
2018-2-27
achim1989
Could you by chance list all the things you already tried? Maybe also in chronological order starting with your first update attempt?
2018-2-27
samflies
New Zealand
davidmartingraf Posted at 2018-2-27 14:53
No Sir - but I did say that I wasn't keen to send it back and would rather try to fix it, as I'm not keen to be without my new toy for several weeks. They only recommended that I add an SD card, which didnt help.
2018-2-27
samflies
New Zealand
achim1989 Posted at 2018-2-27 14:58
Absolutely - thanks you for your help! This is in order
**Installed Go4 App on Samsung S7 and ran firmware update when prompted on startup. Stalled at 83
At this stage I was able to skip the firmware update and on two occasions it let me get the aircraft airborn in my living room for a few seconds. I was able to navigate the camera view etc
**Restarted the aircraft about 20 times with the same result. 83% and stalled
**Installed Assistant 2 on a Macbook Pro and it recognized the aircraft and I started the latest 0200 update, it stalled on 76% complete every time.
** Connected the RC to Assistant 2 and successfully updated to 0100
** Installed Assistant 2 on a Window 10 machine and it recognized the aircraft and I started the latest 0200 update, it stalled on 76% complete every time. Of note - Windows 10 would NOT recognize the RC
** Using Assistant 2 on the Macbook I restored the factory settings of the Aircraft and then tried to run the 0200 firmware update again. Same result. Difference this time is that now the go4 will not start the firmware update and errors out saying its not connected to the aircraft (despite green lights flashing on RC and Aircraft and being able to enter camera view) - Also I can no longer launch the aircraft as it now says it must be updated first.
** Installed a micro SD card - Sandisk Extreme 64GB. This was recommended by DJI support on chat. No change. It did seems to error out a bit quicker after this, instead of hanging on the 76% screen for ages. It errored out and did display a 100% graphic. I'll upload the screen cap I took when I get home.
So I'm at a stand still now - and DJI support still has not replied to my ticket, except for the initially contact 2 days ago where they asked for my details, proof of purchase, serial number etc.
Thanks heaps for the question, and many thanks for looking at my issue. Really appreciate all the help from everyone!
2018-2-27
davidmartingraf
samflies Posted at 2018-2-27 20:13
I understand where you're coming from, it's just like for me with DJI products they're so technologically advanced that fixing my computer is one thing, but assuring my safe flying is another.
2018-2-28
achim1989
samflies Posted at 2018-2-27 20:25
Its just a hunch but have you tried to run the update
- with a different battery in the Mavic Air?
- over the DJI Go App after updating your RC?
Also, as far I'v seen the DJI Assistant allows to export a set of Logfile types from the aircraft. And as I understand these logs are created as soon as the aircraft is powered. It might help if you could export all the log file types that correspond to such a failed update process and post them here on the forum
2018-2-28
fansc456fd18
Flight distance : 57067 ft
Are you using the USB  Type-C cable come with the Mavic AIR ?
It seems DJI Assistant doesn't like most of my 3rd party USB Type-C cables.
2018-2-28
samflies
New Zealand
Hi Folks - it will have to remain a mystery - after trying everyone's helpful ideas I still wasn't getting any luck. I rang DJI support and they recommend getting a replacement. I took everything back to the dealer and they swapped it for a new one without question - awesome! While I was there I decided to upgrade the replacement to the Fly more combo - I'm sure my wife will understand right?
Thanks again everyone for their help.
Cheers
2018-2-28
davidmartingraf
samflies Posted at 2018-2-28 17:59
Cheers
Glad to hear everything worked out for you. Best of luck flying the new Mavic Air.
2018-2-28
QuadKid
Flight distance : 482349 ft
Cheers
I was just going to suggest the return to the seller, This is why I always buy from Best Buy here in the states, they have a 14 day no questions asked exchange policy for all items that require an activation which is plenty of time to ensure the drone is not DOA or defective. I Never want to buy direct from DJI for this reason. If it happens again then I would look closely at your Wifi / Lan situation. let us know how you make out.
2018-2-28
achim1989
Cheers
Probably the most sensible solution. And the fly more combo is always a good idea
2018-2-28
samflies
New Zealand
Many thanks to everyone for the help. The replacement drone firmware updated perfectly first time and I managed a short flight after work. What awesome fun! Now to start planning some missions. Onwards and upwards - thanks all.
2018-3-1
DJI Elektra
samflies Posted at 2018-3-1 12:00
Glad that you solve the problem. The situation was forwarded. Thanks for your update.
2018-3-4
