Who checks the wind before each flight?
12Next >
2477 55 2018-2-25
Blizzard
Flight distance : 173734 ft
Who is using an app lik UAV forecast to check the wind?
It seems to me that a lot of drone pilots are not aware that the windspeed is increasing with altitude.
But not only the windspeed, also the direction of the wind is changing with the altitiude.
2018-2-25
xfirf_
Flight distance : 194911 ft
Me. Using UAV Forecast and my brain when on the spot. :-)
2018-2-25
A CW
Flight distance : 13838848 ft
I do after take off by flying into the wind at 100' AGL then back over head to gauge the impact on the flight. If the speed is half what it should be I don't go higher than 250' up and maintain clear VLOS throughout the whole flight. Wind speed and direction can change in seconds.
2018-2-25
Mavic Ace
Flight distance : 333976 ft
I'm pretty good at feeling the wind blowing and seeing the trees moving. But I've been flying Cessnas for years.
2018-2-25
FlyDK
Flight distance : 1636286 ft
Denmark
I always check the local weather forecast via my PC. Besides that, I use my experience, looking at the sky, on flags and on trees.
2018-2-25
STRIDE8
Flight distance : 1382431 ft
All the time
2018-2-25
eYeSkYeYe
Croatia
When flying above 400', I always check two things.... If NOTAM for my flight is published and active and wind conditions out there.
2018-2-25
Keule
Flight distance : 3733015 ft
i retrieve weather/wind infos from nearby airports reading the most actual METAR / TAF.
2018-2-25
Wyke
Flight distance : 33166 ft
Having flown hang gliders, I’m pretty aware of wind but I do have UAV Forecast to check the forecast as well.
2018-2-25
Landbo
Flight distance : 502792 ft
Denmark
No, putting a finger in the air and looking at the trees. I have never been surprised even though I live somewhere where it's blowing a lot.
Regards Leif.
2018-2-25
spookster
Flight distance : 419649 ft
I alway try to start against the wind while gaining height to see what impact it has.
I do also check UAV Forecast a day/a couple of hours before flight.
2018-2-25
RL_XXI
Flight distance : 456 ft
I use UAV as well but also have my own weather station that I check.
2018-2-25
B1houdini
Flight distance : 927927 ft
I try to look at UAV every time I take off. Here is what is showing this minute.
As you can see they recommend not flying. I can tell the gust here are a little higher then what they say.  UAV has told me it was safe to fly when I can see the windsock straight out. So it is always best to decide for yourself if it is safe to fly or not.
2018-2-25
Lamplighter55
Flight distance : 538596 ft
First thing I do before breakfast! Initially by how much the trees outside the window a moving about - frequency and power, also look up to the clouds and see if the direction of travel is consistent.  Then if it looks like a promising 'flight day' I'll check on various apps both general weather forecast and more specific local wind estimates. Forecasts are important as by the time I maybe on site ready to fly the situation can be quite different - particularly around the equinoxes. Having a bit of a sailing background these checks are second nature.
2018-2-25
KREMi
Poland
always check before flight! those few seconds can save your drone.
just an old habbit from flying other RC
2018-2-25
Dog Flight
Flight distance : 3432156 ft
Checking the UAV app is the first thing I do in my pre-flight. If it's too windy I'm done. Windy.com has some nice forecasting tools also.
2018-2-25
W.Cordes
Flight distance : 138793 ft
xfirf_ Posted at 2018-2-25 09:19
Same here.
2018-2-25
Brad Bilger
Flight distance : 14843274 ft
Every Flight starting the day before.
2018-2-25
Suren
Flight distance : 13425892 ft
South Africa
it is a must for me
2018-2-25
BluesDragon
Flight distance : 634291 ft
Part of my pre-flight check list actually.
2018-2-25
fansf77370fb
Flight distance : 1008924 ft
I always check the local forecast. Anything over 20 mph I don’t fly.
2018-2-25
StanfordWebbie
Flight distance : 178018 ft
I'm with Landbo. I pretty much check the trees and/or flags and just go by that.
2018-2-25
drone_user
Flight distance : 473743 ft
does UAV Forecast have app for apple? I don't have my mini4 to check its coming via ups
2018-2-25
Keule
drone_user Posted at 2018-2-25 21:31
here we go: https://itunes.apple.com/us/app/uav-forecast/id1050023752?mt=8
2018-2-25
drone_user
cool thanks!
2018-2-25
kfloke
Flight distance : 149961 ft
Singapore
I will see outside which quite obvious on my side
2018-2-25
MFPullen
Flight distance : 6257444 ft
Check it everytime...at ground and 300 ft level.
2018-2-26
davidmartingraf
Flight distance : 106566408 ft
I bought an anemometer on Amazon that measures wind speed in MPH and temperature in Fahrenheit (I'm in the US).
2018-2-26
davidmartingraf
MFPullen Posted at 2018-2-26 06:26
Just out of curiosity how do you check the wind at 300 ft level? Do you use an app?
2018-2-26
davidmartingraf
fansf77370fb Posted at 2018-2-25 20:18
I thought the Mavic Pro handles wind better than the Phantom 4?
2018-2-26
rolling56
Flight distance : 138310 ft
I use the UAV Forecast app and look at the tall trees. I also go to the website of the local news station to see if their weather section details match up. Anytime the wind is over 18 mph at 200 ft or higher i don't fly. I rarely fly higher than 200 ft to keep LOS
2018-2-26
rikk08
Flight distance : 21877946 ft
Malta
I do, I usually use windfineder to plan my flights...wasn't aware uav forecast displays also the altitude wind speed so I'll definitely start using that one
2018-2-26
Mars5150
Flight distance : 391493 ft
HI Blizzard, wasn't aware of this APP. Already downloaded, seems great. Will test it next flight. Thanks for sharing.
2018-2-26
Wyke
davidmartingraf Posted at 2018-2-26 06:40
You can use the app UAV Forecast - it gives wind profile from ground to 5000ft
2018-2-26
davidmartingraf
Wyke Posted at 2018-2-26 07:50
Is it fairly accurate?
2018-2-26
JadeBrewerPhoto
Flight distance : 246112 ft
I always check the wind before flying. I fly commercially in the North East and the weather changes rapidly. I have had to ground flights with clients the morning of because of the crazy New England weather. I didn't know about UAV Forecast, I had been using Hover. I am totally going to try that though! It looks really useful.
2018-2-26
Blizzard
I think that quite some fly aways would be prevented if pilots would check better the wind in altitude.
Even with moderate wind on the surface, the force of the wind in altitude can be quite strong.
I also try to fly away against the wind, so, when the drone has to return, he will have tailwind.
UAV forecast is therefore a very good app, but I'm sure there are others. (like the one of PolarPro)
2018-2-26
Wyke
It gets its info from Dark Sky, and uses standard output from most forecast models, apparently
2018-2-26
slimharry
When the UAV app says not to fly do you guys not fly or still take the risk?
What's the limit of flying and noyt flying?
2018-2-26
davidmartingraf
Wyke Posted at 2018-2-26 08:52
That sounds good I'm going to try it thanks!
2018-2-26
12Next >
