In custom stick settings remote, cannot start engines with 2 sticks
959 6 2018-2-26
Cor T K
Flight distance : 14144 ft
When using custom stick settings on the remote of Mavic air I cannot start engines with 2 sticks anymore. What am I doing wrong. Anyone knows the solution? Thank you, Cor
2018-2-26
DJI Thor
Flight distance : 13602 ft
Cor, just to verify, is it the "Stick Mode" that you changed? If yes, the default method for starting the motors might not work, and it varies from your sticks settings. We recommend using Mode 2 (left throttle) in most cases. If you insist customing the sticks, you can try the auto takeoff function on the app.
If you just change the Button Customization on the app and it doesn't work, please also check your stick mode, or provide me the screenshot of the RC settings and the operating video. Thank you.
2018-2-27
Cor T K
DJI Thor Posted at 2018-2-27 00:34
Thank you for you reply
I did a recording of the settings I do. (see link to video)
Starting de engines on the remote does not work anymore. (CSC)
Why do you think CSC  might not work in the custom settings mode?Best regards,
Cor
2018-2-27
DJI Thor
Cor T K Posted at 2018-2-27 01:40
My screen recording
Yes, the CSC doesn't work when it is in custom stick mode in case it causes a confliction.
2018-2-27
Cor T K
DJI Thor Posted at 2018-2-27 03:15
Thanks for your answer. Clear. It is really disappointing that you can't use CSC in this situation.
2018-2-27
djiuser_WGchSiK0VdBI
Poland
Now it launches like this.
2023-2-1
Sean-bumble-bee
Flight distance : 15997 ft
Does that correspond with the stick positions for max descent, max reverse and either max CW yaw & max left OR max CCW yaw & max right?
2023-2-1
