the bald travel
Singapore
StanfordWebbie Posted at 2018-2-26 10:40
When you use the iPhone, do you keep it in any kind of protective case? If so, try using with without the case to see if that is the cause of the heat problem. Do you have anything else plugged into the iPhone while you're using it in the Osmo? I have an Osmo Mobile with my iPhone 8+ - no overheat problem.
Yes with a case, the dji app will cause the phone camera to heat more compare to the native camera app but anyway I didn’t used it that long not sure if it just a normal response and temp will stabilise later on |
