Cetacean
Flight distance : 2271506 ft
Nigel_ Posted at 2018-2-26 15:08
The problem with trying it is that once you have created ripples you have to wait ages for the surface to be mirror flat again, and by then the battery will be empty!
Aloha Nigel,
The answer is in with the posts. For your P4, you will have to test to see what height you have to stay above. As Susan says, stay above 10 meters. But, if you go lower, the VPS will kick in for the P4 Series. The VPS readout gives you a secondary (and more accurate) altitude reading starting at 30 feet. I have not tested for ripples at thirty feet yet, but I doubt that the downdraft will cause ripples at thirty feet. I do not get thin grass movement from my downdraft until 15-20 feet and that altitude may or may not cause ripples. This means you should get a good readout for altitude.
With your camera facing directly down you will see the reflection of your P4. Any ripples will distort that reflection. For the conditions on the day you want to get the shot, test the altitude in an area you will not be using for the shot. Once you get your altitude go to the site you want to shoot and do it.
If you are moving forward with camera facing forward, you can fly closer to the glassy water without seeing ripples because you will be constantly flying over clam water. The smaller the waves / ripples are, the faster the wave propagation dies out so you can fly over the same area more often than you might think. You can also land to wait it out but use a fresh battery when you fly again, so time your batteries well. Over water is a bad time for battery issues.
Hope this helps!
Aloha and Drone On! |
