Active track - Rule of thirds
991 3 2018-2-27
Marcustuck
Flight distance : 147146 ft
Panama
Hi DJI,
Just an idea for a slight improvement to active tracking.  I understand holding the tracked object in the centre of the screen allows for the best tracking.  However it does not make for the best video.
Would it be possible to have an option to select tracking an object in the centre or lower left (1/3 up screen and 1/3 in from the edge) or lower right corners instead. These corner tracking positions may not be able to handle rapidly moving targets but would give great video composition for slower targets.
2018-2-27
chiplifter
Flight distance : 745180 ft
Great suggestion. However, if you record in 4K, an edit in post to 1080p (it is what I used to do) you can scale the recording lossless and apply the rule of third.
2018-2-27
Marcustuck
Panama
chiplifter Posted at 2018-2-27 00:37
I have done this but given the minimum altitude and maximum range for tracking you often end up with very little horizon behind the subject as the camera is looking down.  This option would rase the camera angle which would help a lot.
2018-2-27
chiplifter
Marcustuck Posted at 2018-2-27 04:12
Oh yes, you are right. I did not think of that. Better leave it as suggestion to the engineers of DJI.
2018-2-27
