luciens
I have a P4P that I use with the DJI goggles and they work fine. On the P4P, however, you have to go in with the USB cable so it's not possible to use the goggles and a smart device at the same time. So with the later firmware versions, you have to first startup with a tablet/phone until you get to the "Begin Flight" button in GO 4, then unplug the smart device from the R/C unit and plug in the goggles. Yes, that's really nasty and broken, but it's your only choice (apart from going back to an older firmware which I won't go into here).
Otherwise, the goggles work great with the P4P via USB and head tracking, etc works fine. Keep in mind that the firmware in the goggles is different than GO 4 and not all the features in GO 4 are available. Some of the settings aren't available, but almost everything associated with the camera, resolution, exposure, etc. is available in the goggles.... |
