Jyunte
Flight distance : 2103150 ft
You control the tilt of the camera gimbal using the left controller wheel.
You control panning (left/right) of the camera by turning your aircraft left and right.
Unlike the Inspire series of drones, you cannot control panning the camera independently of the drone itself using only the controller.
As for your sensor issue, connect your Mavic to the computer using a USB cable, run Assistant 2, and turn on the Mavic Pro. After Assistant 2 shows the Mavic has connected, click on Calibration on the left side of the Assistant 2 screen and follow the directions to calibrate the VPS sensors. Make sure you actually click through the prompts to get to the calibration screens - there's one page which appears to display an error message in red, but it's just showing you an example... click Next to continue to the calibration procedure. |
