djiuser_fiQgdFqHaUQg
Philippines
Hey all, I had a 1345T mounting spare so I decided to cut one teeth with medium alloy scissors which took about 10 hard pressings to cut then break one teeth.
The inspire flew with 1 teeth. There's simply no way of it unlocking even with only 1 teeth.
The 1345T is better than the 1345LS system derrived from the inspire 2 because the teeth is thinner on the LS system.
Also the 1345LS makes the motors much heavier with a plate and extra 2 screws.
Also tested while flying touching a bar, the blade only flexes when it touches anything solid. The mounting would never break because the rectangle mold holds the horizontal movements of the propeller.
However if it's an all the way collision, the blades would break.
