After flying the Mavic Air for about 2 weeks I could not figure out the following problem: the footage is quite choppy ( I dont know if this is the right term) during turning the quad, even if turning very slow. My settings are: 2720 x 1530, 60fps, Exp: automatic, ( I have tried manual exposure but ended up with the same results) Cinema mode, Sunny mode, no filter.
I'm sure this has nothing to do with the craft, it's properly me being to dumb to adjust to the right camera settings.
Please see the YouTube upload at: Especially on the end of the video (from minute 2.16 to the end) you can see what I'm talking about.
If you recorded in 2720x1530 at 60 fps, there should be no choppy movements at that yaw speed.
Does your original video do the same, or did the problem occur after editing?
Your YT video has been uploaded in 1080p but is not 60fps. Just the fact that you chose to export, at a different fps than the original, I think could create the issues you have shown. Your choice of editing software of course also can have an impact.
First question is whether the original footage has the same issue. As FlyDK mentioned, exporting it at a different resolution and frame rate can cause some issues. Also whatever settings are chosen on the export can also influence it drastically due to compression and the like. So checking back to the the original footage is important. Can you supply the original file via Dropbox or similar?
Also, what was your shutter speed? To get the smoothest looking movement, your shutter speed should be set at twice the frame rate to get smooth motion blur on moving objects. Since you were using 60fps, your shutter speed should have been set at 120 or very close to that. Since it was a very bright sunny day, unless you were using an ND filter, my guess is that your shutter speed was jacked up really high in order to have proper exposure. This can result in the choppy movements seen in your video.
Check out the following video I made on this topic. The example with the fans in the video demonstrates why the shutter speed is so important.
p.s. The video was made using the Spark, but the same concept applies to all video cameras including the Mavic Air and Mavic Pro.
I use Vegas 12 pro for editing but I did not edit anything other then cutting and inserting the music.
The original footage is the same.
As stated, the camera setting was in auto and I have no ND filters yet.
Sorry, I deleted the original already, but the shutter speed could be the problem, since in auto mode I have not even checked on it.
So I guess, I have to invest in ND filters which brings me to the next question:
Polar pro or FSLabs (they are allot cheaper for 6 filters vs Polar Pro Shutter Collection - Cinema Series 3 filter set).
Thank you so much for your input, I'm pretty new to this hobby
BTW, Kloo Gee, I love your channel and have watched almost all of your videos
Yes, shutter speed maybe also can cause the problem. But whatever, you should check your export settings. It's ok to choose a smaller resolution, but fps should, as far as I know, be the same.
ND filters are of course your choice, but Polarpro is well known for its very good quality.
Another thing I came to think about was whether your recording was stored on internal memory or on an SD card? If on SD card choose a good, fast card - especially for Air.
RobertW Posted at 2018-2-28 15:37
What framerate did you shoot and what framerate did you render in?
Thank you all for your input.
It was stored on a 32 gb SanDisk extrem V30 U3 A1 that should be sufficient for the Mavic.
The clip was shoot in 60 fps and rendered in 29 fps.
Here is another clip it shows even more the problems. Setting is the same and rendering was made in 29 fps.
I'll leave it to those who know more to talk about camera settings. But one thing I'd recommend is to slow down your yaws (sideways revolves). Use two fingers on the stick - one at the base to limit how far you can push the stick, and the other on the stick doing that pushing.
I have seen the same thing and it seemed much more pronounced than anything I have seen on the Phantom 3, Mavic Pro, Phantom 4, or Spark. It might be time to experiment with ND on the Air. This is also the first time I have recorded much in 4K. I am starting to wonder if there is something strange with the yaw gimbal stabilization. I would (and I will) experiment with gimbal up/down motion at similar speeds as yaw. If the same effect exists then it is video settings / frame rate / editing, as others have noted. If it doesn't exist in pitch camera adjustments then there may be something goofy with the gimbal stabilization in the Air's firmware.
Is your card the real thing, that is exact the symptom of a low speed card, did you buy it off eBay by chance? Set yaw movement to about 50 and try that.
As I have said, It was stored on a 32 gb SanDisk extrem V30 U3 A1. I purchased the card at Amazon and I don't think they are selling fake cards.
I have not tried the gimbal up/down motion, but thanks for the tip, I'll try it today.
Half Chrome Posted at 2018-3-1 17:38
TroutboyNZ Posted at 2018-3-1 17:45
I have checked the original footage from the sd card and surprise, surprise, the video looks much better. I guess the choppiness occurs during editing. Does anybody uses Sony Vegas pro 12 for editing??
If so, can you please tell me the settings you use.
Thank you.
RobertW Posted at 2018-3-1 09:04
Sorry, to me this looks like the cached video in GO 4 but by no way like the original footage from the SD card. How and where to have you exported the original footage?
Wachtberger Posted at 2018-3-2 09:54
Thank you for your reply. I have not uploaded the original footage from the sd card to YouTube, the uploaded clip is rendered with Sony Vegas.
edit: I see in YT description vegas pro 12, even old ones allows to pick framerate on rendering without problems.
to clarify what is faulty, upload movie without any changes (so that one from card) to Youtube, it allows a 60fps vid - then we will know it's too slow card, or you mess something in edit
and honestly - if from a dynamic scene in 60fps video You are cuting every 2nd frame (that's basicly what You do when going from 60>30fps) it must be more choppy then pre-edit!
RobertW Posted at 2018-3-2 10:04
Sorry again, but you have not answered my question. Please do what our dear fellow pilot KREMi is suggesting here above but please make sure that you use the original footage directly from your SD card, not via your mobile device! Thank you, thereafter we might be able to help you further.
Wachtberger Posted at 2018-3-2 12:59
Thank you for your reply. I do have the original footage downloaded from the sd card to my computer, unfortunately, after importing it I formatted the card, so the only copy is on my computer.
The clip is about 3.5 GB and don't know how to cut it without a rendering software.
RobertW Posted at 2018-3-2 13:07
That is ok, just upload it to Youtube as it is without any handling. Will take some time (especially for Youtube to process) but it is worth the effort to find out where your problem is located (e.g. with Mavic Air, or with the software or settings you are using).
Wachtberger Posted at 2018-3-2 13:11
Ok, I'm uploading right now, it will take some time Thank you
You are welcome! As mentioned I believe it will help to come to the root of the problem. But after the upload, processing on Youtube will also take some time. I'll try to stay awake until it is finished. Should I not manage, I shall provide my feedback tomorrow. And I am sure that in the meanwhile others will be able to jump in for feedback.
Yup just uploading right to youtube should still retain most of its quality... point is this is the original footage and it's not handled through some other software
Wachtberger Posted at 2018-3-2 14:23
It should be soon finished, just let him do what he has started. This way we can be sure that there has been no other interference.
Of course, but it's a waste of time to upload this much when a lot less could be more than enough.
Wachtberger Posted at 2018-3-2 14:30
I agree, but in this case it seems to be the safest way to exclude any interference in order to come to the root of the problem.
I understand that, completely. But VLC player don't edit as such - it simply copies a clip of the original video, from one selected point to another, and automatically saves it to the hard drive. It can not be done in an easier way. The only thing I doubt a little is whether it can be carried out in 4k.
