QuadKid
Flight distance : 482349 ft
AG0N-Gary Posted at 2018-3-1 11:46
Ever since my P3A lost its brains and flopped over upside down and propelled itself into my concrete driveway, I have a little procedure to go through when I launch. I start it on the ground and let it sit until all is stable on the screen, looking through menus to see that everything is set properly. After that, I'll launch a few feet in the air and check battery temperature if it is cold out. I'll let it hover until the battery temp gets to around 26. I do some low speed maneuvering back and forth a few feet and up and down, just to see that each direction is stable, especially when hovering. Then I go fly. While flying in cold, never jump into sport mode and hit the throttle. The battery can have a cell fail and shut the whole thing down without warning. Fly gently, like you would a car when starting it cold. When it warms up, you can get a little more aggressive with it. It's an expensive "toy" to get careless with. It is an aircraft and you are the pilot, responsible for its safe operation, etc.
Also note that your incoming video is stable when your antennas are properly aligned with the drone at somewhat short range. I had mine look like it had iffy signal, even though it was within 100 feet of me once or twice. I landed immediately and shut EVERYTHING down completely, and then rebooted every device. All was stable after that. Be forewarned - unreasonably unstable video from the drone, or any erratic behavior should cause you to land immediately and do something about it, even if it is only a reboot.
Words of Wisdom here, never take flight until you here "Home Point has been updated, Please check it on the map" no poetry=no fly. |
