iPad mini 4 "CPU fully loaded". Cheap Android alternative?
1931 12 2018-3-1
Pasta Rhymes
Flight distance : 19304 ft
Hi there,
in recent months my iPad mini 4, iPad Air and my iPhone 6S have become too weak to run the DJI Go 4 app. I am using the Phantom 4 Pro.
Almost immediately after I turn it on i get the "Mobile device CPU fully loaded" message and the image transmission stops working.
Is this CPU error message just a bug or have my iOS  devices really become obsolete? I don't really feel like spending  hundreds of dollars on another iPad.
Are there any reliable Android tablets out there that work with DJI Go 4 and ideally Litchi as well?
2018-3-1
Tripp
Flight distance : 2241401 ft
I have been using the Samsung Galaxy Tab S3 with very good results with my P4p.  I have seen that warning when using my MP using an iPad Mini2.  Sadly, it seems like new versions of the Go App can make a device that used to work perfectly become too slow to run the software.
2018-3-1
DJI Susan
Hi Pasta, the reminder of "Device CPU fully loaded. Related performance will be affected" is a new app feature, which can detect the usage of the CPU for the mobile device. Please keep the mobile devices from the direct sunlight, and clean the storage to see whether it helps.
2018-3-1
djiuser_iGJqCoTNTQSa
There is absolutely zero reason for an iPad Mini 4 to be too weak to run Go 4. I'm guessing you never clear your cache.
2018-3-1
Tripp
This video might help
2018-3-2
Pasta Rhymes
I should have mentioned that this iPad mini 4 is my dedicated drone tablet with almost no other apps on it. I've been flying drones for almost 3 years now. Before every flight I clear the cache and make sure no other app runs in the background. I even tried rebooting the iPad prior to each flight and I have over 10GB of free space. Still, every single time I get choppy video transmission and loss of signal. That problem wasn't there before DJI GO 4. What else can I do?
2018-3-3
Tripp
That is discouraging.  Your iPad model number is A1538  or A1550?
2018-3-3
Pasta Rhymes
Yes sir, it is. Model number is A1538.
2018-3-4
billnelson
Crickets from DJI. I've flown P3 and P4, P4Pro - all with my trusty iPad 4 mini - and have NEVER experienced the video dropout and CPU loading phenomenon until this new 'feature' was rolled out. Take a quick peek and you can see experienced flyers have been grousing about this job-ruining issue for several years. I can't WAIT unit another software/firmware update clears this up once and for all. OR, another company with more interest in their user base than their bottom line steps up to provide the reliability that pros require.
2020-5-18
billnelsonnelsonmedia.com
Update: this morning while flying my drone I encountered this CPU loaded error. Immediately landed and closed out the DJI go app. Launched it again, and took off. No problem afterward. Go figure!
2020-5-21
fansb8c31278
Has anyone come up with a fix for this yet I have same issue with my iPad mini 4 with the go fly app for the mavic air 2?
2020-5-30
Mark Turner
watching with interest as I have the same set up/issue. No issues using the mini 4 when I had the P4 or mavic air 1.. Just done th latest round of updates so will see what effect that has in due course...Forgot to add the screen is sluggish to respond to commands.. Works ok with my iphone 8
2020-8-15
EleJota
Flight distance : 1113307 ft
I have the same problem using my mavic 2 pro I use ipad mini 4 128gb with the free cache last version of the djigo4 app and last version of the ipados 13.6 operating system months ago I had no problem using my ipad mini 4 ... could you be problem because of ipados 13.6?
It always fails me when I turn on the drone, first, the cpu overloaded warning appears and then there is a lot of lag in the image and it is impossible to fly.
I have a Oneplus 5T Android I have never had a problem with any kind of overloaded cpu warning.
2020-9-1
