Punchbuggy
Flight distance : 483166 ft
As others have stated, it's not a matter of recording time - it's a matter of file size limitation. FAT32 has a max file size of 4Gb (rounded), so depending on the resolution you set your recording to will depend on how many minutes you capture per file. Setting 4K vs 1080 will clearly fill that 4Gb faster.
But the break in files should be seamless, and you can always post-edit the segments together for a contiguous record. Just remember to save the newly combined video using the same frame per second rate, else it may appear jerky on playback. |
