Mavic Pro flight time average
10135 13 2018-3-2
Mavic_Pilot73
Chile
Hi guys can you tell me what is the flight time average for Mavic Pro on this two scenarios:
1.- All time flight recording
2.- All time just flight, no record no photo
the specs said up to 27 mins of flight but in which conditions?
regards,
Mavic_Pilot73
2018-3-2
integer
Flight distance : 113355784 ft
Greece
wind is the big enemy
2018-3-2
Danny-B-
Flight distance : 306640 ft
27mins is under optimal conditions and you probs wont really ever acheive this ... its quoted as being 0wind and flying 15mph forward or something (more efficient flying forward) .. you can however expect 24mins standard flight time, i have got 24mins easily on a few occasions and landed with 20% (dont fly lower than 20%)
I dont think record/non recording really effects the flight time in the slightest.
2018-3-2
A CW
Flight distance : 13926112 ft
Air temperature, wind speeds, flight speeds, age of battery, using intelligent flight modes like active track, using sport mode, flying long distances from your position - all of this will impact on flight times. Video recording with have a minimal effect. My flight times landing on 10-15% with my Mavic Pro Platinum vary from 22-28 minutes per battery averaging 25 minutes.
2018-3-2
Bekaru Tree
Flight distance : 15513100 ft
South Africa
the 27 min advertised is in the perfect case scenario for the mavic as dannyb points out. Any deviations from this 'absolute ideal' eats a bit extra battery - but not so much as to make a significant difference. flying in sport and hovering consumes more battery than flying forward in regular speed. Fighting against wind and flying in cold temps will also take extra out. my batteries are now 1 year old, i always fly in sport mode and often in pretty strong wind - in these conditions i get about 17 min (landing with about 20% battery)
2018-3-2
Brad Bilger
Flight distance : 14843274 ft
A CW Posted at 2018-3-2 13:24
Also dependent on Altitude.  Where I normally fly is 600' above sea level.  On vacation in Colorado in the mountains, my max was 13,110' above sea level.  At home, I get 25-27 minutes no problem.  In Colorado, I was getting maybe 15 minutes per battery.. and I wan't pushing it hard.  Thinner air, motors work harder
2018-3-2
A CW
Yes, altitude too and hovering times - my point is that there are many variables that impact on flight times and not just recording video
2018-3-2
Mavic_Pilot73
Chile
Thanks to all of you guys for your comments and share experiences now I'm  very clear about the real world conditions flight vs the manufacturer specs.
great flights to all!
2018-3-5
B1houdini
Flight distance : 927927 ft
I am at 5200 feet and I usually get any where between 17 to 22 minutes. Less then when I first got my MP. 20 to 25 minutes of flight time.
I think as the batteries get old they do loose a bit of power, Loss of power means less time in the air.
2018-3-5
Woe
Flight distance : 4129268 ft
B1houdini Posted at 2018-3-5 12:26
Agreed. My very first I got with my Mavic still get me 19 mins. I Rarely fly my battery under 25%
2018-3-5
A CW
Very true - the cells will naturally degrade over time. If you hold down the power button on the battery for several seconds without releasing when you first press it will light up the LED's. Each LED light that flashes shows a 12.5% loss and each that do not light up at all show a full 25% loss. When one LED is completely lost it's time to stop using the battery as the mAh will be less than 75% of capacity. To revive the cells it's advised to discharge the batteries to 8% then fully recharge the battery to 100% every 20 flights (according to DJI). Store the batteries at 40% power level and don't feed them after mid night
2018-3-5
Wachtberger
Flight distance : 261509 ft
A CW Posted at 2018-3-5 12:52
"...and don't feed them after mid night"
Are full moon nights also critical? ;-)
2018-3-5
B1houdini
Thanks A CW
2018-3-5
A CW
Wachtberger Posted at 2018-3-5 13:01
Only if you have silver bullets in the house
2018-3-5
